Jensen CH4001 CD/receiver
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=3497
Printed Date: April 24, 2026 at 2:34 AM
Topic: Jensen CH4001 CD/receiver
Posted By: fmpaul
Subject: Jensen CH4001 CD/receiver
Date Posted: September 10, 2002 at 11:10 AM
posted_imageHi folks:  Can anybody tell me what the identity of the 4 RCA outputs are on this unit? I just purchased a new one for my stepdaughter's F150 from FRY's, in the sealed box...and...guess what? Neother the Install Manual, nor the Operation Manual, make any mention of RCA outputs whatsoeverposted_image And, to add insult to injury, the web site they show on the front of both manuals, www.jensenaudio.com, takes you to a redirect site that has no connection to Jensen that I can find. I am replacing a JVC KD GT5 tuner/CD changer that has only RCA outs. I need to know what are front and what are rear. The harness that comes with it is not marked either. Some customer support.posted_image Your help is much appreciated. Thank you.
Posted By: chriswallace187
Date Posted: September 10, 2002 at 11:07 PM
I don't know much about Jensens, but I recall Sony used to use RCA inputs for their changers.  If they're not marked as outputs that may be the case.  If they are outputs, you can check which one is F and R by hooking one pair up(assuming the deck and amps turn on), fading it all the way forward or backward, and seeing which way maintains the sound.
C Renner's Auto Electronix
Posted By: fmpaul
Date Posted: September 23, 2002 at 2:46 PM
Thanks Chris.
It has a black pair and a gray pair. Black is front/gray rear. The one hitch was the Jensen has no remote amp +12 volt wire. Luckily, the power antenna wire stays hot all the time the HU is on and worked out just fine as a remote amp wire. Aside from the pain in the a** the outboard converter box is, it worked out pretty well. Took me about 30 minutes to do the swap.
Thanks again to all.
