4 gauge in line Fuse ?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35347
Printed Date: March 30, 2026 at 10:08 AM
Topic: 4 gauge in line Fuse ?
Posted By: onsatmex5
Subject: 4 gauge in line Fuse ?
Date Posted: July 10, 2004 at 1:07 PM
Is it ok to fuse my 4 gauge power wire for the amp, At the battery "and" also another place. Because I bought a amp install kit and needed to have more lenght to get it back into the trunk, and I am using a in line fuse to splice the 2, 4 gauge pieces so it will be long enough.
Posted By: jugga-nemo
Date Posted: July 10, 2004 at 1:29 PM
It's perfectly fine to use a second fuse on the wire. It's not necessary by no means, but will offer more protection and a better connection where the two wires will splice. It would probably be best to use the same size fuse in both places, but then that seems like common sense (to me at least).
5.25" Components & 5x7 Coax Kappas w/Power Acoustik OV4-800
KAC 7252 powering 2 D3 8" Diamonds
KDC-MP728, KGC-4042A
Posted By: stevdart
Date Posted: July 10, 2004 at 1:55 PM
Actually, that's a good idea to use the materials you have on hand.  As long as the second fuse is in a position somewhere in the car that you can easily get to it in case of a power outage.
