bad amp or sub?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35373
Printed Date: March 31, 2026 at 3:08 AM
Topic: bad amp or sub?
Posted By: deejwireless
Subject: bad amp or sub?
Date Posted: July 10, 2004 at 7:56 PM
i have eclipse 8152dvc x2
jbl600.1 x2
audio control eql
coustic xm6
one of the sub move more than the other .
do i have a bad sub or one of the gain on the amp is  to high ?
Posted By: mikedawg
Date Posted: July 10, 2004 at 8:20 PM
good question. are they in different enclosures. one might have some sort of leak in it if they are. thats all i can think of but im not a pro
always looking for new info and willing to give it
Posted By: Clean Install
Date Posted: July 11, 2004 at 7:34 PM
I would check the gains
If we learn from each success and
each failure, then we can improve ourselves
Posted By: Alpine Guy
Date Posted: July 11, 2004 at 9:21 PM
did it work properly before, , or are you just hooking it up now?
Posted By: markcars
Date Posted: July 12, 2004 at 2:45 PM
Best and quickest test would be to switch your subs and see if the effect reverses in channels. If after switching the same sub performs weakly, that sub is to be investigated furthur such as above posts. Box different or sub itself. If upon switching the sound remains same, meaning the other sub takes the "weak" effect, then its the amp or wiring and the subs are both same/ok.
