remove door panel Highlander
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35378
Printed Date: March 31, 2026 at 6:30 AM
Topic: remove door panel Highlander
Posted By: phunboy
Subject: remove door panel Highlander
Date Posted: July 10, 2004 at 10:14 PM
I'm trying to replace the tweeters and speakers in the front door of a 2003 Toyota Highlander.
Doe anyone know how to remove this panel?
Posted By: Clean Install
Date Posted: July 11, 2004 at 7:30 PM
check for screws and take off slowly posted_image, dont force it posted_image
If we learn from each success and
each failure, then we can improve ourselves
Posted By: Javelin3o4
Date Posted: July 11, 2004 at 10:07 PM
Posted By: markcars
Date Posted: July 12, 2004 at 2:50 PM
I wish I had this info when I was doing it for the first time. phunboy, did you get to change them? Which tweeters are you putting in? I thought of chaging mine too but did not yet. I changed all, except the tweeters. I changed HU, 4 door speakers, and put 2 new amps, a sub. The 4 door speakers have tweeters in them as well and sound amazing so I did not change the stock tweets. After reading your post, Im thinking of it too. Which tweeters did you get?
Posted By: phunboy
Date Posted: July 18, 2004 at 1:15 PM
I tried removing the door panel as suggested in the scosche link above, and I'm unable to remove the the door opener cup as outlined in step 1. Has anyone had success removing this piece? I found all other retainers/fasteners in the door panel, just stuck with removing this door opener cup.
It says pry out, then forward.... that doesn't work!!
Anyone with experience with removing Highlander door panel? Help!
