Mount my amp on top of sub enclosure?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35409
Printed Date: March 31, 2026 at 11:26 PM
Topic: Mount my amp on top of sub enclosure?
Posted By: onsatmex5
Subject: Mount my amp on top of sub enclosure?
Date Posted: July 11, 2004 at 1:42 PM
Is it ok to mount my amp, on top of my sub enclosure? I want to use small screws that will not go through the box to mount it. I am running out of room in mt trunk. :)
Posted By: DYohn
Date Posted: July 11, 2004 at 2:40 PM
I can't say it better than this:  https://www.bcae1.com/amplfier.htm
This is a good page for anyone to read, but to find the specific information about mounting your amplifier, scroll down after you visit the link.
Date Posted: July 11, 2004 at 4:18 PM
I read that whole thing at. {https://www.bcae1.com/amplfier.htm} Thank you Great info..
I really do not have a choice I have no more room :{ My sub box is really well braced, So I think it will be ok. this is the box I am using.
posted_image
Posted By: pimpincavy
Date Posted: July 11, 2004 at 4:34 PM
I just installed my system and mounted the amp on the box. I also needed the trunk space, plus its only a temporary amp, and I have a very solid box. I think that most amps today should be able to hadle the vibrations.
Posted By: Teamrf
Date Posted: July 11, 2004 at 5:02 PM
I always make custom amp racks for amps. But if trunk space is an issue you want to think about another place.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: stevdart
Date Posted: July 11, 2004 at 6:51 PM
No matter how well built that box is, the amp will take a pounding when those subs are hitting.  Look at the space you want the amp to occupy, and figure out how to get an isolated shelf in there to connect the amp to.  If there is no way but to use the box as the support, isolate the mounting shelf with springs.  The spring feet would be screwed directly to the box, and then the support shelf will be screwed to the spring feet, so that there is no screw or bolt directly contacting both the sub box and the amp support shelf.  The amp would then be screwed to the shelf.  You will get a vibration-free amp this way.
Date Posted: July 11, 2004 at 6:58 PM
I already mounted my amp on the sub box, although i will be getting a new amp sometime. When I get my new amp what should i do about the screwholes in the box?
Posted By: stevdart
Date Posted: July 11, 2004 at 7:32 PM
Put screws back in them.  Paint the flat head type wood screws to match the cabinet carpet, and the carpet pile should hide them pretty well.
