Mounting sub amp, Is it ok to do this?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35435
Printed Date: April 01, 2026 at 9:10 AM
Topic: Mounting sub amp, Is it ok to do this?
Posted By: onsatmex5
Subject: Mounting sub amp, Is it ok to do this?
Date Posted: July 11, 2004 at 10:25 PM
Is it ok to mount my sub amp upside down? It is a kicker 850.2 I want to mount it under the rear deck between the 6x9's in the trunk.
Posted By: customsuburb
Date Posted: July 11, 2004 at 10:27 PM
No, the amp will overheat because heat rises and if the heat sink is upside down then the heat will rise right back into the amp.
Posted By: auex
Date Posted: July 11, 2004 at 10:39 PM
Absolutely not, it is desinged to dissipate heat to the top of the amp like customsuburb said.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: July 11, 2004 at 10:50 PM
How about mounting it suppended from the rear deck with the right side up, not up side down, with a 1 inch air space above it? The problem is I have very little room :(
Posted By: bryceyaworsky
Date Posted: July 11, 2004 at 10:55 PM
sure, you could try that but you'd better make sure that you have a couple of, or one large fan(s) blowing right through the 1" air-space. This is especially true in the summer time.
Posted By: flatulatta
Date Posted: July 12, 2004 at 3:53 PM
ive got mine mounted horizontal... on the back of my box.... its not overheating one bit... its a jbl 600.1 incase ur wondering.. but im in an suv...
