95 Toyota Avalon receiver and amp wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35546
Printed Date: March 30, 2026 at 6:04 AM
Topic: 95 Toyota Avalon receiver and amp wiring
Posted By: jakediggity
Subject: 95 Toyota Avalon receiver and amp wiring
Date Posted: July 13, 2004 at 3:55 PM
I was wondering if there is anyone out there who actually has an Avalon and has installed a head unit, and if so how you went about it exactly.  I was also wondering how much power the factory amp in an avalon has.  And my last question is about amps themselves.  If you have a receiver that has 70 peak watts 60 rms and you have to go through an amp, say a factory one that may produce less power than your receiver, would it be better to bypass it all together and connect directly to the speakers or run through it anyway.  What I'm basically asking is if  when an amp inside a receiver is wired to another amp do the two powers add up or do the speakers they're connected to only feel the power of the amp?
Posted By: Ravendarat
Date Posted: July 13, 2004 at 4:05 PM
I dont have an avolon but I would probally just run new wires unless there is a simple by pass kit. Also no deck on the market prodeces 70 watts max 60 watts rms. Not unless that 60 watts rms is the total power of all 4 channels combined.
Posted By: kgerry
Date Posted: July 13, 2004 at 5:59 PM
the proper way if you want to use the factory amp is to use Metra's 70-8112 amp integration harness...it will require your HU to have 2 sets of RCA preouts... otherwise i would bypass the factory amp and go direct to speakers.... it takes all of 10 minutes or to bypass the amp if need be.....
BTW, most factory amps use an IC output stage similar to most HU's...so dont expect the same volume level or SQ you would expect if you were using a reputable aftermarket amp.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: Drey
Date Posted: July 13, 2004 at 10:21 PM
beat me to it... just get the metra part. it's easy
Date Posted: July 14, 2004 at 6:21 PM
Panasonic jsut came out with a new HU that "Claims" 70 x 4 peak and 60 x 4 rms.  Its called Panasonic MXE-CQ-c9800u, and thanks everyone for your help.
