infinity kappa 572.5 need crossovers?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35651
Printed Date: March 29, 2026 at 7:35 AM
Topic: infinity kappa 572.5 need crossovers?
Posted By: milenko
Subject: infinity kappa 572.5 need crossovers?
Date Posted: July 15, 2004 at 4:50 PM
Hey guys, need some quick help.
I just got two sets of Infinity Kappa 572.5's for my 96 Mustang GT.
Each box came with two crossovers.
Do I need these crossovers to run the speakers? It said in the "intruction manual" that I could cause damage to the speakers if I didn't use them.
I'm powering the speakers from a pioneer deck.
If I don't need the crossovers, which side do I connect the wires to?
If I do need the crossover, should I just connect the two wires going IN to the crossover to the deck?
Posted By: DYohn
Date Posted: July 15, 2004 at 5:29 PM
Yes, absolutely you need to use the crossovers.  The woofer connects to the low pass output side and the tweeter to the high pass output side.  I believe if you use the factory supplied wires, the lugs are sized so that they only connect to one place on both the crossovers and the speakers.  And yes, you connect the speaker output from the deck to the crossover "in."
Posted By: milenko
Date Posted: July 15, 2004 at 5:35 PM
Perfect. Thank you for your detailed response.
