enough power for 4 jl 12w3d4 subs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35889
Printed Date: May 13, 2026 at 5:08 AM
Topic: enough power for 4 jl 12w3d4 subs
Posted By: skylark
Subject: enough power for 4 jl 12w3d4 subs
Date Posted: July 20, 2004 at 2:09 PM
hey im kinda of confused here after visting jl audio web site. i just bought 4 12 w3d4 subs brand new on ebay and i plan on running all four of them in an 93 k-5 blazer. im gonna wire them together to recieve an 2 0hm load. And im using the jbl 1200. bp1 amp older version. Would that be to much power or just right because i know jl audio understates their rms. Also how much power will each sub be recieving? like 300 apiece or more?
goingcrazyonsound
Posted By: customsuburb
Date Posted: July 20, 2004 at 3:23 PM
That amp should be perfect for those subs (each sub would recieve 300 watts each continuously, which is the reccomened amount of power for them).
Posted By: skylark
Date Posted: July 20, 2004 at 5:51 PM
so they wont blow because i blown 2 kicker compvrs but i was running and jbl 1200 watt amp of each set of subs
goingcrazyonsound
Posted By: forbidden
Date Posted: July 20, 2004 at 7:15 PM
Any sub can blow if they are abused. Abuse can take many forms, like a sub that is hitting a seat. Running the amp into clipping. Clipping the output of the cd player. Not allowing a sub to cool down. Not saying that this will happen to you, but a sub does not just blow by itself, something must cause it to.
Posted By: skylark
Date Posted: July 20, 2004 at 9:35 PM
i just think they blew because the amp was to powerful for the subs but when one blew i just ran them off one amp then another one blew so what should i set the crosser over on the jbl 12000.1 amp to when im running the jl audios? im looking for max spl out of my sealed enclosure and i listen to mostly hip hop and r&b
goingcrazyonsound
Date Posted: July 20, 2004 at 10:31 PM
The crossover setting depends on your main speakers. If they are fairly large (6.5 to 6x9s) then around 80Hz is usally a good choice, but if they are smaller (5.25 to 3.5) then anywhere from 95 to 130 Hz is suitable. You should play some music that has good vocals (preferably a male voice) and set the filter to the frequency that makes your main speakers blend with your sub.
