95 Jeep YJ stereo
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35930
Printed Date: May 14, 2026 at 1:46 AM
Topic: 95 Jeep YJ stereo
Posted By: petecame
Subject: 95 Jeep YJ stereo
Date Posted: July 21, 2004 at 1:27 AM
I have a 95 YJ (wrangler) and i am having problems with the wiring diagrams please post a diagram and how do i access th 4x6 speakers in the dash
Posted By: forbidden
Date Posted: July 21, 2004 at 12:56 PM
You either take off the windsheild and entire dash or you twist your hand and fold it in half, then give it another twist until it resembles a pretzel. Make sure that you remove the 3 heavy bolts that are above the speakers at least. Next the speakers are held on by speed nuts onto welded on bolts. Once these nuts come off the speaker will have to be removed from the backside over these long bolts. On the drivers side make sure that you unbolt and remove the underdash lighbulb or it will burn you real good (leads to a yelling session and beer break - sometimes throwing of tools etc) You will also need a deep socket to get at these speed nuts, chances are that they will come off quite easy. The drivers side is worse than the passenger side but it can be done. If you do not have small hands, find someone that does, it is much easier.
------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: kgerry
Date Posted: July 21, 2004 at 5:51 PM
Metra makes a set of adapter plates for this vehicle if you are wanting to put in standard 4x6"s.....
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
