cavalier wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36432
Printed Date: May 11, 2026 at 8:00 PM
Topic: cavalier wiring
Posted By: chevsucks
Subject: cavalier wiring
Date Posted: July 29, 2004 at 8:26 PM
 I see that there are two different gray wires and two different yellow wires. How do I tell which for power and which is for speaker?  Please Help!!!
CHEVY REALLY SUCKS
Posted By: sparkie
Date Posted: July 29, 2004 at 9:12 PM
Use a digital volt meter. One gray wire is the left front speaker negative and the other is the dash illumination lead. (Goes to 12 volts + with parking lights on and dims with dash dimmer). The two yellows are 12 volt + ignition and the other is the left rear speaker negative. It would be a good idea if you haven't cut off the factory plug yet to buy a install plug that takes all the confusion out and makes for a clean install. Any stereo shop will have one.
sparky
Posted By: pimpincavy
Date Posted: July 29, 2004 at 9:32 PM
I had the same problem in my cavalier, not sure what chevy was thinking with that wiring. I used trial and error to find which was the rear left speaker and which was teh power/dimmer.
