Silicone to seal subs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36464
Printed Date: May 11, 2026 at 6:03 AM
Topic: Silicone to seal subs
Posted By: MBZ oe
Subject: Silicone to seal subs
Date Posted: July 30, 2004 at 1:51 PM
Should you apply a bead of silicone to seal subs to enclosure? I always do, but I just heard someone say that you want the subs to have a little room to breath?
What is the "right way"?
Angel
BOOM, BOOM, BOOM BOOM....
Posted By: Robert@zapco
Date Posted: July 30, 2004 at 2:24 PM
I have never used silicone to seal the subs to the box. What I normaly use is a foam tape, like they would sell at Home Depot for sealing windows and doors. It comes in different thickness and is also seals really good. As far as letting your subs breath......I have always have them sealed as much as possible. the tighter the box the tighter the response.  But that is just my oppinion
Robert Rugani
Sales and tech support
Director of show vehicle design
Posted By: dudek38
Date Posted: July 30, 2004 at 2:29 PM
you don't want any air leaks in the box. use thin weather stripping with the sticky tape on the bottom. apply it to the bottom of sub. most good subs come with it. also silicon makes it a nightmare when taking the subs out for whatever reason.
owner of
Motion Marine & Car Audio
the florida keys
Posted By: DYohn
Date Posted: July 30, 2004 at 2:39 PM
"Room to breathe"???  Who told you that?  They are wrong.  I always use silicone rubber RTV to seal speakers into enclosures.  If you need to pull a speaker you simply pull it away and the rubber will peel off.
Posted By: MBZ oe
Date Posted: July 30, 2004 at 3:03 PM
>"Room to breathe"???  Who told you that?<
I think that the person who said that was trying to help someone keep a crappy box together. I recently read that on here or another board. I always use a bead of Silicone RTV.
Posted By: dudek38
Date Posted: July 31, 2004 at 11:21 PM
if the box is flat and the hole isn't too big and the screw holes arent stripped, i feel that silicon is unnecessary. the thin weatherstipping is the best way to go.
owner of
the florida keys
Posted By: archemedes
Date Posted: July 31, 2004 at 11:24 PM
I use the foam rubber, but I have had people use silicone the down side to that is if you want to change something it's a royal pain
Posted By: defective
Date Posted: August 01, 2004 at 10:52 AM
poll!!
i'm with foam tape...... well..... it really depends, if im putting a sub in a carpeted pre-fab, i dont wanna have all that RTV stuck to the cloth,,,, so I'd use tape, but if your working on a fiberglass or mdf peice, then it's always nice to have the option.
