Alpine MRV-F302 amplifier problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36572
Printed Date: May 09, 2026 at 12:52 PM
Topic: Alpine MRV-F302 amplifier problem
Posted By: jonbth
Subject: Alpine MRV-F302 amplifier problem
Date Posted: August 01, 2004 at 6:43 PM
I have a Blaupunkt Las Vegas reciever and infinity reference component speakers which work great. I bought an Alpine MRV-F302 amplifier off Ebay that was still factory sealed.
The problem I'm having is after hooking up the amplifier I'm barely getting any sound out the speakers.  I checked and double checked the connections and checked voltage and it's 12+ volts at the power and amp turn-on terminals. The ground should be good although I don't really know how to check it.
I tried everything I know.
Please help!!!
Posted By: nychris2004
Date Posted: August 01, 2004 at 6:50 PM
how do you have the speakers hooked cup to the channels?....u might have them hooked up wrong.
JVC HU
Rockford 501bd (500 watt rms)
Rockford Hx2 Rf2212 (1)
Kenwood 6969 (4)
---If You Learn Something New Everyday And Teach It To Someone Else, Everybody Would Still Be Dumb As Hell!---
Posted By: jonbth
Date Posted: August 01, 2004 at 6:53 PM
I'm pretty sure I have the speakers hooled up right. I'm using channels 1 and 2 and have them wired to my crossovers. I only have one set of components in my truck. I tried bridging the amp also but still not much sound.
Posted By: customsuburb
Date Posted: August 01, 2004 at 7:14 PM
Did you set the gain control correctly? Are the speakers wired in phase? Do you have the filter set on high pass or low pass?
Posted By: jonbth
Date Posted: August 01, 2004 at 7:38 PM
I feel like an idiot. I had the reciever fader set all the way to the front. I readjusted it and it fixed the problem. Thanks for all the replies.
