system noise help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36638
Printed Date: May 08, 2026 at 4:18 PM
Topic: system noise help
Posted By: insanity
Subject: system noise help
Date Posted: August 02, 2004 at 3:25 PM
ok... have a suzuki liana wagon... factory hu, jl components front and rear, jl 4channel on highs, 2 channel on one 10w7.. have upgraded to larger battery, installed 4 guage grounding kit in engine room, 0 guage pos cable to rear into pyle 5 farad cap as dist. o guage to ground and 4 guage from cap to amps... had a whinning noise in front left spk that turned out being a faulty amp.. replaced and now have very slight alt whine.. also has 4 guage from alternator to batt.. car just developed a popping noise in spks that increases in speed as the volume increases.. is it possible that the pac adapters are bad or wrong for this car??.. power and signal cables are nowhere close except at amps, and everything is tight!!
please help!!..... confused in cayman
Posted By: Ravendarat
Date Posted: August 02, 2004 at 5:06 PM
Could be your converter but if its a popping noise I would guess the ignition system. Id check and make sure your spark plug wires are tight and free of defects. Also try to keep some distance between your power wire and your spark plug wires
