Noise Noise Noise
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36976
Printed Date: March 13, 2026 at 9:47 AM
Topic: Noise Noise Noise
Posted By: fastinanaurora
Subject: Noise Noise Noise
Date Posted: August 07, 2004 at 9:38 PM
Today I installed 6.5 Kicker dx 60
a Kicker KX 600.1 mono amp
a rockford 400s 2channel amp
A rockford C10-03 Capacitor
Into a 98 oldsmobile aurora.
Then discovered the rockford amp wasn't working right, so i wired a 4 channel 1200 watt volfenhag, then I got rcas which were later removed stuck, into the amps rca inputs.
After that was fixed, I discovered some nasty Noise, that ish was terrible I wen't around the block only to discover I can't drive my car with the system on. Ridiculous
What Can I do to get rid of this noise? Noise consist of When I step on the gas a hissing/whining, when I use my power seats I hear noise whenever I touch the button. Feedback noise when I turn my system off.
Somebody Please Help me
What makes my car Bang:
Kicker KX 600.1 Mono amp (2004)
Kicker Solobaric L7 10 (2004)
Long Ported Box Single
Kicker 200.4 4 Channel(2004)
Kicker DX 60 6 1/2
Rockford Fosgate FRC3369 6x9
Posted By: stevdart
Date Posted: August 07, 2004 at 10:27 PM
Take it all out and reinstall.  Take your time because as you know Rome wasn't built in a day.  You're not at a point where troubleshooting is going to help you fix the problem...the install is bad.  Go over all the basics:  power wiring and fuses, ground wiring, RCA cables...Get it all down on paper as a plan of action and start over.  That's my take on it, anyway.
Posted By: Alpine Guy
Date Posted: August 07, 2004 at 10:43 PM
definately check the ground wire between your alt/ body/ and battery.   Time and time again i always fix noise problems by cleaning the contact points for the main ground wire at the battery, , i even add an extra 4 gauge wire to the body, , works 95% of the time
