98 firebird, best place to put subs?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37212
Printed Date: March 30, 2026 at 2:03 PM
Topic: 98 firebird, best place to put subs?
Posted By: ballerwannabe4
Subject: 98 firebird, best place to put subs?
Date Posted: August 11, 2004 at 11:42 PM
i have a 1998 pontiac firebird with t-tops, and i can't seem to find any place that i can put the subs, they don't seem to fit anywhere, any suggestions? i'm not the most knowledgable about stereos, so any help would be greatly appreciated, thanks
Posted By: tylertime
Date Posted: August 12, 2004 at 7:24 AM
i beleive that the rear of the vehicle is the popular place to put a sub in these cars
i'm not 100% on how its set up in your car...but my suggestion would be to look on the net for enclosures for your car, see where they go, and start from there
or go on car domain and see where other 98 firebird owners have their subs,
that is of course...someone else on here cant help you, sorry if i didn't at all!!!
Posted By: Charles_R_H
Date Posted: August 12, 2004 at 11:27 AM
try q-logic or pro box
ELECTRONICS RUN OFF OF SMOKE, WHEN YOU LET THE SMOKE OUT THEY STOP WORKING
Posted By: forbidden
Date Posted: August 12, 2004 at 1:23 PM
If you want to keep your t-tops in the stock mounting location, then you are left with three areas. One is behind the rear seat, a long slender box will fit right there, size is about 1.5 cu.ft. if I remeber right. Next is the spare tire wheel well, a custom fabricated box is needed here as wella s the loss of the spare tire. Lastly is the opposite corner, this is where the factory Bose sub is. If it is there, remove the Bose enclosure and replace it with one made by Q-Logic or fabricated out of mdf and fibreglass. A single 10" sub can be placed in this area.
Posted By: racer427
Date Posted: August 12, 2004 at 4:32 PM
Here is one from MTX         https://mtx.com/caraudio/products/enclosures/CF10.cfm
Alpine CDA-9833 HU
Diamond Audio M661 Components
MTX Thunder T6.6 Components:rear fill:
Cadence Q400 4 Channel Mains + rears
Thunder 801D Subs
MTX 1004 10's
Dual 4g wire to rear
4g grounds
Posted By: carson6901
Date Posted: August 12, 2004 at 5:03 PM
I had a '97 T/A in which I removed the T-top retainers from the rear well and installed a pre-made fitted enclosure which fit very well. As for T-top storage, a rasied support was fabricated to sit over the amp. In result, the T-tops laid horizontal behind the rear seat on top of the support over the amp. It looked awesome.
