mdf tricks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37344
Printed Date: May 07, 2026 at 8:50 AM
Topic: mdf tricks
Posted By: mobile E
Subject: mdf tricks
Date Posted: August 13, 2004 at 6:51 PM
Are there any tricks to get mdf to contour to the inside of a trunk...? Thanks Matt ------------- everything stolen :(
Workin on a new system :)
:V:
Peace in the middle east
Posted By: fugit
Date Posted: August 13, 2004 at 6:54 PM
Make a template with cardboard then use a jigsaw. My grandfather showed me how to do something similar. He made it look easy but he has 50+ years of experience so good luck.
------------- "I'm Rick James bi***, enjoy yo' self Ah Ah Ah"
Dave Chappelle as Rick James
Posted By: auex
Date Posted: August 13, 2004 at 6:55 PM
Define contour, bends/curves or just cut with no gaps? Yeah, use a table saw to turn the mdf into saw dust. Then mix the sawdust with wood glue until it reaches the consistency of paste. Then all you have to do is spread it with a putty knife in the form you want.
Actually there are a couple different ways to bend MDF, but it really depends on what form you want to achieve. Another product is called "bend-a-board".
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: mobile E
Date Posted: August 13, 2004 at 7:42 PM
no i dont want to bend it... im talking about the first reply, stuff like that, like making a carboard template and wood glue thing, those are all good ideas. thanks, any more?? ------------- everything stolen :(
Posted By: skylark
Date Posted: August 13, 2004 at 8:35 PM
is that an serios idea. Auex cause explain that answer in detail sawdust and wood glue...........
------------- goingcrazyonsound
Posted By: auex
Date Posted: August 13, 2004 at 8:51 PM
No, not serious. Just a joke, although that is all that mdf is. Seriously, this is the way I like to do what you are talking about. First cut the panel as close to the way it needs to be. Then tape off the area of the trunk that the panel will lay on. Notch the edges of the panel with a jigsaw like this "\ / \ / \ /". Lay the panel where it will go and then mix up some bondo. Apply the bondo to the edge of the panel where it will meet the trunk. Sand the bondo down level to the panel. You will have the perfect fit panel with minimal effort.
Posted By: promodeepcycle
Date Posted: August 16, 2004 at 2:59 PM
you can alsao get a bendable ruler ... and a contour gauge....as far as bends use 1/4 inch mdf..brace it with 3/4
------------- dont be a pet monkey ..use your dmm
