Changer install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37471
Printed Date: May 08, 2026 at 3:22 AM
Topic: Changer install
Posted By: TheSaint421
Subject: Changer install
Date Posted: August 16, 2004 at 3:55 AM
I have an Audi A4 that I was asked to install a changer into, with a factory system in it. what brands of changers will work with the factory unit?
thanks guys, Mark
Posted By: switch_hitter
Date Posted: August 16, 2004 at 6:12 AM
only a changer from the factory....
Date Posted: August 16, 2004 at 6:14 AM
I have seen changer adapter cables that will let me use a panasonic changer with my A4, are there any other options? or if you could , do you know of any places to get those cables?
Mark
Date Posted: August 16, 2004 at 6:23 AM
if you could use a panasonic changer, then my guess is that your factory hu is made by panasonic or something of the sort....i would check with the factory for that cable
Date Posted: August 16, 2004 at 6:40 AM
it's a bose HU actually, all the cable does is do the conversion in the wiring harness
Mark
