type Rs, sealed or ported?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37477
Printed Date: May 08, 2026 at 5:46 AM
Topic: type Rs, sealed or ported?
Posted By: customsuburb
Subject: type Rs, sealed or ported?
Date Posted: August 16, 2004 at 9:30 AM
Using two 12" Type Rs, Which would be louder, 1.25 cf sealed with 400 watts RMS or 2 cf ported (no idea what to tune it to) with 400 watts rms (would this sub be able to handle 400 watts RMS in a ported box or is 300 enough to get really loud). If you havn't noticed already I want to get as loud as possible with this setup.
Posted By: Ravendarat
Date Posted: August 16, 2004 at 1:21 PM
If its tuned correctly I would have to say the ported enclosure is going to be louder.
------------- double-secret reverse-osmosis speaker-cone-induced high-level interference distortion, Its a killer
Date Posted: August 16, 2004 at 4:48 PM
Could the Type Rs handle 400 watts RMS each in a ported box though? -------------
Date Posted: August 16, 2004 at 4:51 PM
As long as the amps are set up properly, I dont see a problem with it.
Date Posted: August 16, 2004 at 6:27 PM
Ok last question. Would running 400 watts RMS to each sub in a sealed or ported enclosure that i mentioned above, be much louder (like noticably louder), or would an MRD-m501 be enough to get them to slam just as hard? -------------
Posted By: jakedubb
Date Posted: August 16, 2004 at 7:08 PM
You could get away w/ using the Alpine amp but they only put out 425 watts @ 2 ohms and under powering the type R's isn't a good idea. The 400 watts ea. is perfect. They'll handle a lot more power than that if it's set up right... I'd have to suggest going to a sealed enclosure for better sound quality, but if all you want is sloppy "loud" bass the ported is best for you...
Date Posted: August 16, 2004 at 7:15 PM
I'm doing this for a friend and he listens to mostly rap so ported should be fine. Which of these setups should be louder? An MRD-M501 (it outputs 550 watts RMS at 2 ohms), two 12" Type Rs in a 2 cf ported box. An MTX 801D (800 watts RMS at 2 ohms), two 12" Type Rs in a 1.25 cf sealed box. -------------
Posted By: Alpine Guy
Date Posted: August 16, 2004 at 9:26 PM
he would definately like the ported set up more if he likes rap, unfortunately im not great with porting box's, , so im no reall assistance with porting those subs.
------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Date Posted: August 16, 2004 at 9:43 PM
Would 275 watts RMS from that MRD-M501 be enough for those subs in a ported box, or would they like 400 watts RMS better? Sorry to ask so many questions, I just want to make sure everything will peform its best.
Date Posted: August 16, 2004 at 9:53 PM
they would like 400rms better. Iv put 501's on the pre loaded alpine ported box with the R-12 and the sub didn't bottom out with 550rms. It shure was loud tho, , almost too loud.
