DEH-7200
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37484
Printed Date: May 08, 2026 at 6:50 AM
Topic: DEH-7200
Posted By: racer427
Subject: DEH-7200
Date Posted: August 16, 2004 at 12:07 PM
Hey guy's. a quick question again,
     This deck has 2 sets of rca's. They are split up. One set of RCA's can be set for sub or full range and the other set (according to the manual) is for front channel. I am running both front and rear speakers plus subs with 2 amps. How should I utilize these RCA connections.
    BTW, I am also using a sony XEC-500 indash crossover unit
Alpine CDA-9833 HU
Diamond Audio M661 Components
MTX Thunder T6.6 Components:rear fill:
Cadence Q400 4 Channel Mains + rears
Thunder 801D Subs
MTX 1004 10's
Dual 4g wire to rear
4g grounds
Posted By: Ravendarat
Date Posted: August 16, 2004 at 1:12 PM
correct me if I am wrong but I believe that that sony needs one set of RCA inputs then splits it up to fron, rear and sub woofer. If I am indeed right, then run the fronts off the deck to the sony, then run the RCA's to each specific amp from the labled outputs on the crossover, IE front to front amp rear to rear amp and sub to sub amp.
Posted By: racer427
Date Posted: August 16, 2004 at 1:47 PM
You are right about the crossover splitting the signal. I have it hooked via the non fading output. I was just woundering if there was a better way to hook it up using both rca output's.
Alpine CDA-9833 HU
Thunder 801D Subs
MTX 1004 10's
4g grounds
Date Posted: August 16, 2004 at 2:37 PM
nope
