Problems with stock AC/Delco Head Unit
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37696
Printed Date: May 11, 2026 at 6:24 PM
Topic: Problems with stock AC/Delco Head Unit
Posted By: r-mbaker
Subject: Problems with stock AC/Delco Head Unit
Date Posted: August 18, 2004 at 8:43 PM
I am having a problem with my stock head unit.
Here is my system set up so far:
Speaker level converter (speaker to RCA)>Audiocontrol Overdrive (line driver)>Xtant A4004>Boston Pro 6.53 front
Xtant A4004 also runs an Xtant A series 10" from the rear channels (RCA's run from front channels "output" into rear channels "input")
Here is my question.  When I have the balance control on the stock head unit in the "middle", it cuts the power WAY down to the sub.  When I turn it either right or left, the sub level is much louder but of course the front stage is greatly reduced for the opposite side.  WHY IS IT DOING THIS???  Is there any cure for this other than a new head unit (I know that would be best but trying to make do on a budget for a couple of months!).
Thanks for any advice to make this sound as good as I can for now!
r-mbaker
Posted By: dudek38
Date Posted: August 18, 2004 at 8:51 PM
it sounds like the polarity on your loc are incorrect. that problem usually happens when there are polarity problems. try switching your leads at your loc.
owner of
Motion Marine & Car Audio
the florida keys
Posted By: furflier
Date Posted: August 18, 2004 at 8:56 PM
I agree with dudek38.
