MTX 8000 subs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37846
Printed Date: April 11, 2026 at 6:08 PM
Topic: MTX 8000 subs
Posted By: racer427
Subject: MTX 8000 subs
Date Posted: August 21, 2004 at 2:01 PM
Hey guy's, Just bought a pair of MTX 8104 10" subs off of E-Bay. Just woundered if anyone here has had any experience with these subs. I have read alot of reveiws but would to hear any personal experiences. Also, which is better for these subs, selad box or slot type vented enclosure? I listen to alot of rock and alternative. ------------- Alpine CDA-9833 HU
Diamond Audio M661 Components
MTX Thunder T6.6 Components:rear fill:
Cadence Q400 4 Channel Mains + rears
Thunder 801D Subs
MTX 1004 10's
Dual 4g wire to rear
4g grounds
Posted By: vdubmk4
Date Posted: August 21, 2004 at 2:41 PM
YESS, you have the same subs as i do, I put mine in a sealed box and they sound beautiful and I'm only runnin 200 watts to each at the moment. When i get my fiberglass enclousures done i'll be runnin 360rms to each, and good lord do they hit with 360 watts. Excellent choice my man, I love mine.
------------- Fortune: You will continue to take chances, and be glad you did.
Posted By: ttronic
Date Posted: August 31, 2004 at 5:40 PM
10s are an awsome sub for rock and alternative but only in a sealed box. Sealed alows great responce and awesome mid to high bass. With rock you deff need the responce with the always canging frequencys. Ported boxes tend to tune lower and sound great for long drawn notes. When it comes to punchy bass ported boxes tend to sound really muddy.
Posted By: racer427
Date Posted: August 31, 2004 at 7:00 PM
Well, I listen to rock and alternative mostly and 10's are my choice the the style. I am currently building a box for them that will run right around .62 cft per side and I really hope these things rock. I will be driving them with at 500 watt RMS mono amp so, that should be pleanty of power for them I hope. I have heard that they are pretty power hungry.
Thunder 801D Subs
MTX 1004 10's
4g grounds
Posted By: pimpincavy
Date Posted: August 31, 2004 at 7:56 PM
For rock definatly go with a sealed box, not to mention the fact that they are soooo much easier to make.
Posted By: jeffchilcott
Date Posted: August 31, 2004 at 9:24 PM
ported boxes work just fine for rock if they are vented correctly. as long as you stay with a wide tuning freq. and dont have a massive vent mach you will be fine. I will listen to a rap cd and then throw in tool, NIN, pantera and everything sounds just fine
------------- 2009 0-1000 Trunk WR 154.0DB 2009 1001+ Trunk WR
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: Ravendarat
Date Posted: September 01, 2004 at 8:02 PM
Is that all the space you have availible to you, cause thats pretty small for those subs, I usually put them in 1.2 cubic foot sealed boxes when they were current. In a box that small they are gonna be power hungry, as they are in general anyways. Either way though it should sound good.
------------- double-secret reverse-osmosis speaker-cone-induced high-level interference distortion, Its a killer
Posted By: racer427
Date Posted: September 01, 2004 at 8:51 PM
MTX doesn't recomend over a 1 cf box per sub. I have built it to their recomended size of .63cf per side and will be tuning them in around 40hz. I have used a sound deadening spray on the inner walls of the box to (hopefully reduce accoustic resonense. If it doesn't sound good and hit hard, then I will just build a bigger box for them.
Thunder 801D Subs
MTX 1004 10's
4g grounds
Date Posted: September 01, 2004 at 8:58 PM
remember .63 is the internal demensions - wood ports -sub displacement
2007 World Record
Date Posted: September 01, 2004 at 9:20 PM
I know what MTX recomends on their sheets, but I am telling you man, I have been dealing the stuff for 3 years and I am telling you strait from the horses mouth, what they recomend is actually the absolute smallest internal dimensions you can possibly get away with, and not nessasarily Ideal.
Posted By: Esco1977
Date Posted: September 02, 2004 at 7:09 AM
so what size would you reccomend for 1 12 9500?
Posted By: fuseblower
Date Posted: September 02, 2004 at 10:27 AM
I would recommend a box a little larger than the .63 cubic ft. Since, you are using the specs to tune the box I would go a little larger because the .63 would limit your bass. Also, after building 4 different sealed enclosuers for MTX's the larger boxes normally go deeper and are more detailed when coming to lower bass notes. I would say go with about .88 cubic ft. You can fill the current box that you have that should give you a little more bass. If you want to get into deep ground shaking tones build a 1 cub box and you will definitely feel the bass.
Date Posted: September 02, 2004 at 10:30 AM
For the 9500 I would go exactly with the specs that the web site has listed. These subs are made to really pound and to go up against some good competition. Taking this info. in hand MTX has tested these subs to really try to out do there comp. If you go with a box a little bigger than they recomend you will be ok. The MTX boxes are normally built for somewhat stiff bass notes..
Posted By: racer427
Date Posted: September 02, 2004 at 9:17 PM
OK Fuseblower, I am gonna go to .88 cf. I will see how it sounds there. If it's not seep enough A little polyfill should help right? ------------- Alpine CDA-9833 HU
Thunder 801D Subs
MTX 1004 10's
4g grounds
Posted By: racer427
Date Posted: September 03, 2004 at 6:36 AM
OK guy's, here are the calculations for the box. 28"wide x 13" deep x 12" height . - the 3/4" divider and that should be pretty close to .88 Cubic ft. Ok, actual Cubic ft. will be .8647 per side. ------------- Alpine CDA-9833 HU
Thunder 801D Subs
MTX 1004 10's
4g grounds
Posted By: racer427
Date Posted: September 03, 2004 at 8:59 PM
Ok, the box is finally done. Here it is. What do you think? https://pg.photos.yahoo.com/ph/racer4272000/detail?.dir=/eddf&.dnm=846a.jpg https://pg.photos.yahoo.com/ph/racer4272000/detail?.dir=/eddf&.dnm=3da4.jpg https://pg.photos.yahoo.com/ph/racer4272000/detail?.dir=/eddf&.dnm=4253.jpg ------------- Alpine CDA-9833 HU
Thunder 801D Subs
MTX 1004 10's
4g grounds
