in the door wire color for 91 F250
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37953
Printed Date: April 08, 2026 at 11:40 PM
Topic: in the door wire color for 91 F250
Posted By: equium
Subject: in the door wire color for 91 F250
Date Posted: August 23, 2004 at 2:47 PM
hey all,
i just put a set of 6.5 inch jensens in the doors of my 1991 F250.  i re-used the factory wires in the door. i'm a little worried about my polarity choice with the colors.
the right door had black and white wires, the left door had black and orange.
i assumed that black was the GROUND (-) and the white and orange were the positive (+).
did i assume correct? anyone run into this?  i don't have an expert ear to tell if one is out of phase or not.
thanks
Posted By: insanity
Date Posted: August 23, 2004 at 3:18 PM
yep ur cool... worst case if you run into this problem, balance to one side or the other.. if it sounds better when all on one side then it may be out of phase
Posted By: dangerranger96
Date Posted: August 23, 2004 at 3:42 PM
Posted By: equium
Date Posted: August 23, 2004 at 3:51 PM
wow, that was sure a fast response.  thanks for the links.  i used the factory wire harness kit i bought at a wally mart that worked fine.  everywhere i looked didn't have the actual colors INSIDE the doors.  i guess it would have been too much to ask of ford to leave the wire colors the same.  thanks again.
