2004 hyundai accent, not enough power
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38018
Printed Date: April 08, 2026 at 8:04 PM
Topic: 2004 hyundai accent, not enough power
Posted By: ynothere
Subject: 2004 hyundai accent, not enough power
Date Posted: August 24, 2004 at 11:53 AM
I'm trying to install a cd player into my 2004 hyundai accent, but i can't get enough power. The radio doesn't work when the car is in accessory mode, but the radio will play when the engine is running. The cd player won't work under either scenario.
There is a voltage drop from 13.8 v down to about 8.4 v when i try to turn on the radio (with the engine off). After the voltage drops, the radio turns off and the votage comes back up. Then the radio turns on and the voltage drops, and so on. It's about a 5 - 7 second cycle.
The same thing happens with the engine on if I try to play a cd.
What can I do?
Posted By: dragonrage
Date Posted: August 24, 2004 at 11:55 AM
It sounds like you have a short in that CD player. Check your wiring and try the deck in another car or on a bench.
2009 Pontiac G8 in planning stage
HU: ?
Speakers: ?
Amps: ?
Posted By: ynothere
Date Posted: August 24, 2004 at 12:30 PM
Probably not. I pulled the cd player out of my old car, where it worked just fine. After my first attempt at the new car, I put it back into the old car, and it worked fine again. I'm kinda stuck. The factory tape deck works in the new car & the cd player works in the old car.
Posted By: fuseblower
Date Posted: August 24, 2004 at 1:46 PM
Check your fuse.  It maybe to weak to keep supplying your radio with juice but to strong to blow when loaded.
Posted By: kgerry
Date Posted: August 24, 2004 at 5:07 PM
some Hyundais used common ground speaker wiring, which your HU will see as a short, whereas your old vehicle may have used isolated wiring, grab a meter and verify for any commons to each other or to chassis.....
try just hooking up power ( & ground obviously ) and connect one speaker out to a test speaker, does it work fine?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: ynothere
Date Posted: August 24, 2004 at 5:10 PM
Kevin,
I havn't connected the speakers yet. This problem is happening with the ground, always hot, and ignition hot connected only.
Posted By: kgerry
Date Posted: August 24, 2004 at 5:26 PM
do toy have access to a meter?  use it as an ammeter and see what kind of current is being drawn on first the constant and then the switched line.....
assuming you have tapped into the correct wires it's not logical for battery B+ to drop so low... what happens if you hooked this deck directly to the battery?  what happens if you twist Acc and B/U together and go to one or the other... i suspect a faulty circuit somewhere or something is hooked up wrong
go direct to the battery and see what happens first... there shouldnt be any difference in doing this or doing it at the radio harness....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Posted By: kgerry
Date Posted: August 24, 2004 at 5:27 PM
do you have access to a meter?  use it as an ammeter and see what kind of current is being drawn on first the constant and then the switched line.....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Posted By: auex
Date Posted: August 24, 2004 at 5:45 PM
Where are you grounding? If you say I am using an aftermarket harness then are you sure there is a ground wire on the factory harness. If the ground is good and you are sure you have the right wires tagged for power then your radio is damaged.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: ynothere
Date Posted: August 31, 2004 at 3:46 PM
Thanks guys,
The "wire directly to the battery suggestion" was the fix. It worked fine in that scenario. So I'm bringing in a direct wire from the batery to the cd player. It seems that the stock wiring wasn't of a thick enough gauge.
Posted By: kgerry
Date Posted: August 31, 2004 at 3:58 PM
MAKE SURE TO FUSE the wire within 12 inches of the battery if you're gonna do this.... i suggested it as a diagnostic measure, not a fix.......
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Posted By: ynothere
Date Posted: August 31, 2004 at 4:02 PM
Can I fuse the groung (-)? I'd prefer the ground since I have a second "ignition on" power I'll be using from the factory radio harness.
Also, the new cd player has a built in 10A fuse, should I use the same resistance for the new inline fuse by the battery?
Posted By: kgerry
Date Posted: August 31, 2004 at 5:12 PM
no,   fuse the power... the idea of a fuse is to prevent the vehicle from burning down if the wire somehow gets shorted to ground... if you fuse your ground wire and the power wire shorts going through the firewall your vehicle will burn down.....
think about it..........
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
