SPL, how to get louder?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38058
Printed Date: April 10, 2026 at 4:08 AM
Topic: SPL, how to get louder?
Posted By: brandon8686
Subject: SPL, how to get louder?
Date Posted: August 24, 2004 at 11:09 PM
Hello everybody, I want everybodys input on how to get louder than i already am I have:
2 S12L7 Kicker subs.
1 bp1200.1 JBL amplifier
ported box 5.25 cubic feet.. fiberglass
clarion dxz853 deck..
and a phoenix gold bass cube
Im driving a nissan 240sx coupe and the subs are in the trunk.. its sorta customized to be more hatchback like for better airflow into the cab.
What can i do to improve my spl? im probably gonna soundproof everything and upgrade my deck to an excelon eclipse or alpine but other than those improvements im stumped on what to do to gain a few db.. any ideas???
I got in sensored recently with a termlab and i hit 150.2 db
Posted By: xtreamcc
Date Posted: August 25, 2004 at 12:20 AM
you hit 150 and ur concerned about not enough SPL? You trying to go deft or what dude? Anyway, with ur current setup there's not much you could do except maybe get a second amp and push both subs to their max, but that would probably destroy them in that ported box..... but you'd be louder posted_image
"Shiny chrome when used in conjunction with bikini models is particularly effective in inducing brain deficit disorder"
02 Jeep Grand Cherokee
Monster System on its way.
Posted By: gibo
Date Posted: August 28, 2004 at 12:16 AM
Well you could add one more JBL bl 1200 and run one to each sub that would get you up to 153 db, double the power to go up 3 db, then you need more voltage and amperage to power the amps, you might want to try one of these if you don't already have one: https://www.batcap.net/index1.htm
Posted By: markcars
Date Posted: August 29, 2004 at 7:17 AM
You have 150.2 db and thats not enough for you? I assume you are not continuously listening to those volumes are you? Because at those levels, you can easily damage your ear drums. Please don't damage your hearing.
Just out of curiosity, what did you use to measure the db level on your speakers?
Posted By: jeffchilcott
Date Posted: August 29, 2004 at 2:01 PM
150.2 on the term lab and you want more,   what class are you running in?
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: Steven Kephart
Date Posted: August 29, 2004 at 5:37 PM
Where was the mic placed when you hit that score?
With SPL, there is no replacement for displacement.  So if you can get more radiating surface, or further movement (larger enclosure/more power) at the frequency you are playing, then you will be louder.  Other ways of doing it is making sure your enclosure walls are perfectly rigid.  You will lose SPL if the box flexes at all.  You should also do what you can to make the vehicle rigid (within the rules of the organization you are entering).  That will reduce losses as well.
Steven Kephart
Adire Audio
Posted By: mconway0000
Date Posted: August 31, 2004 at 2:20 AM
dynamat or tsunami silencer or anything else of the like should help a bit, maybe double layer it
