Facts about Sealed vs. Vented
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38070
Printed Date: March 22, 2026 at 9:47 AM
Topic: Facts about Sealed vs. Vented
Posted By: dbdraggirl
Subject: Facts about Sealed vs. Vented
Date Posted: August 25, 2004 at 8:30 AM
Ok.. correct me, definetly if i am wrong.. but this is what I have found about sealed vs. vented..  True or not true.. Help if out if i screwed it up somewhere..
Selecting an Enclosure
Sealed vs. Vented
Sealed Enclosure
Sealed enclosure are simple to build and install, they provide good transient response,
Low frequency extension, (12 dB/octave) and high power handling in a small box.
As with all enclosures they should be sealed airtight.
A foam gasket is recommended between the woofer and the box.
Box performance is measured by the Q factor (ripple) and F3 (Hz /-3dB)
Smaller sealed boxes, have better power handling, due to less cone excursion, and they have a higher frequency roll off and more output gain, (Qtc1.0 to Qtc1.25 or higher).
Which in most applications is better for SPL.
The trade off with smaller Sealed box is that you loose deep bass extension.
The larger sealed box, is better for deep bass, with better transient response, due less ripple,
(Qtc .707 to Qtc .850) which is ideal for Sound Quality systems, but you loose power handling and SPL.
Do Not exceed the Larger recommended box size and the rated RMS power.
For sound quality we recommend to cover, at least one wall with one or two inch of Polly fill material.
For SPL competition no Polly Fill is necessary.
Woofer displacement should be added to the internal Box volume.
Vented Enclosure
Vented enclosures are more difficult to build; usually they are bigger then sealed boxes.
They provide better power handling down to the port tuning, and less acoustic distortion.
They are more efficient, (+3 dB or more for the same size sealed box system) play louder, and tune
lower in frequency, (F3) than sealed box, but rolls of at faster rate, 24 dB/octave which relates into
a loss of deep bass extension below the port tuning.
The type of alignment, Fb (Hz) and Gain (+dB) determine box performance.
Power handling below the port tuning is poor to the point of damaging the woofer if excessive power
is applied, due to driver unloading (as if it is working in free air).
The type of music played is critical in choosing box size and tuning frequency.
For Rock, Disco and Country 42 to 45 Hz
Wide range, Rap, and Boom type bass 36 to 40 Hz.
Jazz, Classical, Bass CD’s 32 to 38 Hz.
Do Not boost equalizer frequencies that are lower frequency then the port tuning.
Care should be taken wen building vented enclosures, to add to the box internal volume the port
Displacement, as well as the woofer displacement.
For SPL competition the port tuning it’s not necessarily the best frequency to achieve a high SPL score.
Vented Enclosure Design and Construction
When calculating enclosure volumes remember to add woofer and port displacement.
Avoid perfect cubic box shapes for better sound quality.
The use of square section port is a better choice for high excursion woofers to reduce port noise and more SPL output.
Simple Math For Enclosure Volume
Enclosure volume Width x Height x Depth divided by 1728 = Cub ft.
To calculate port displacement use the same formula
Port displacement Width x Height x Length divided by 1728 (depth of port) = Cub ft. (volume)
Port area Width x Height = Square inch
If port length is to long to fit in the box you can turn it
Around the back wall forming an L shape.
To find the area of a round port,
Measure the port diameter and divide by 2 = radius (1/2 of diameter)
Then multiply
(radius x radius x 3.14) = Square inch
Port Conversion
Keep distance from end of Port to back of box the same or greater then the Port width or diameter (A = B)
Round Area sq.in
3 in. = 7.10 ( 7.10 x 1= 7.10)
4 in. = 12.57
6 in. = 28.27
5 in. = 19.64
8 in. = 50.26
Girls can do anything guys can do!!
2~12" Kove Armageddon Z's
US Amps 2000x
US Amps 4300x (mids & highs)
US Amps X2R Crossover
Clarion DXZ745MP
2~Kove 5 1/4" KC Components
CompuStar Alarm :o)
Date Posted: August 25, 2004 at 4:42 PM
make it a sticky?? because there is quite a few questions about what kind of box to build..  posted_image
US Amps 2000x
Clarion DXZ745MP
CompuStar Alarm :o)
Posted By: stevdart
Date Posted: August 25, 2004 at 5:09 PM
No offense, db, but I think you're a little all over the place with that subject.  Linking to the various sites you lifted the information from will end up making a lot more sense to the inquisitive reader.  Just my h. o.    :)
Posted By: auex
Date Posted: August 25, 2004 at 5:40 PM
Don't forget there is an actual webpage behind the forum that is just full of this kind of information.
The reason people ask questions like "what kind of box should I have" or "what amp/sub should I get" are from inexperience, or stupidity. The problem with these questions is that they are subjective and based on an individuals experience. The only way people will ever know what "they" want is to go listen to the equiptment in person.
For example, I will never own a ported enclosure in one of my vehicles, they just sound like total crap IMO. I also will never own audiobahn, jensen, sony, or any other b line equiptment.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
