crossover on amp and other ?’s
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38160
Printed Date: April 08, 2026 at 9:57 PM
Topic: crossover on amp and other ?’s
Posted By: nyguy4u
Subject: crossover on amp and other ?’s
Date Posted: August 27, 2004 at 12:00 AM
What's up guys. I have a few questions that i'm hoping some of you can answer for me.
My friend who works at a shop locally here totally rewired my system for me at no charge because he enjoys doing it for his close friends.
Let me really quickly describe my system. As for the power, I have a 1 gauge power cable ran to 2 caps, 1 gauge from there running to a distribution block, then from there, 3 seperate 8 gauge wire ran to each of the 3 amps, that each drive a 15" W3v2.
As for the RCA part, I have the LPF preout from the deck running into a Audio Control 24xs, then the LPF from that to a Audio Control Matrix Line driver, that splits out 3 pairs of RCA's to each of the amps
Now for my question, the bass before he rewired everything was fine. After he rewired it, it seems a little muddy and lower volume. I was looking at the LPF crossover on the amp, and it goes from 50 to 200 Mhz. He has it set in the middle. How generally should the crossover be set on the amp?. Same with the gain, it's set at exactly the middle. But for some reason, i'm lacking bass. Originally, each amp was bridged and ran in mono to each sub, but he switched the speaker wire to run out of the left channel, and set the amp to stereo. What is the purpose of that?. He claimed the amps can not handle a 2 ohm load when bridged (which I know, because I contacted Kenwood), but can when wired in stereo. Is that true?. My friend isn't a fly by night installer, he's been doing this for years, and is very respected in our area. But, I was just curious if that was the case. Also originally, all my wire from the cap and beyond was 4 gauge, and he switched it to all 8 gauge. The amps are rated at about 450 or so RMS, but 1,000 peak, even though I feel that # is inflated. But does everything I just mentioned that he did sound justified?. Also, how in fact should the crossover and gain be set if I want maximum bass?.
Second part of my question is regarding power issues. After playing my setup for 30 mins or so, my battery light on my dash starts to blink. Does that mean the alternator can not keep up with the current?. I have a yellow top battery, but still the stock alt. Should I upgrade my alt, and if so, what generally do most people get as far as amps?. I am just assuming that since my battery light is blinking after about 30 mins of use, that that's what is. I might be wrong.
I hope someone can answer my questions!
Thanks guys!.
Posted By: stevdart
Date Posted: August 27, 2004 at 11:02 AM
1.  Post the model # and specs for the amps.  Currently, it appears that the output is 1 X __@ 2 ohm stereo for each amp.
2.  Are the subwoofers D2 or D4?
3.  And are both audio control units situated close to the head unit?
Posted By: nyguy4u
Date Posted: August 27, 2004 at 11:29 AM
model # is KAC 929, and specs are as follows..
3 Way Ready Yes
Amplifier TypeDual Channel
Bass BoostWith Bass Boost
BrandKenwood
BridgableBridgable
Manufacturer Part Numberkac-929
MOSFET amp Yes
UPC019048127587 • 1904812758
Dimensions
Depth11.69 in.
Height2.25 in.
Width15.25 in.
Miscellaneous
Product ID20295231
Other Features
Input Voltage14.4 volt
Performance
Bass Boost Frequency90 Hz
Frequency Response20 Hz - 20000 Hz
Low - Pass Frequency50 Hz - 200 Hz
Signal to Noise Ratio100 dB
THD at Rated RMS Power.08 %
Power Output
RMS Power at 2 Ohms230 W x 2
RMS Power at 4 Ohms150 W x 2
Subs are D4
And the audio control units are no where near the deck, they are mounted to the box.
Posted By: heavilymedicate
Date Posted: August 27, 2004 at 11:38 AM
A crossover point of 125 is to high for 15's.  You might use a high crossover point on 8's to increase their response, filling in the sound a bit, but not a 15.  Your getting less power because the amp is no longer bridged (I think, if i understand your correctly).  It is running stereo, with one channel to each voice coil.  It would be better for your amp this way because each of your voice coils are 4ohm (making an assumption) and is a stable load on the amplifier (your amp should not get as hot now).  Your getting less sound because your delivering less then half the watts you were before.  Bridged, your output doubles at 4 ohms. But you were at 2ohms, so it should double again.  Being that your amp is not stable 2ohm bridged, we can assume you are running just above your stated 4 ohm bridged RMS.  Your gains can vary.  Different amps have different sensitivity.  So if you take 3 different amps(same wattage) and put the same signal to them, you most likely would have to set the gains in three different places to achieve the same amount of output.  Also, decks put out different amounts of voltage.  So lets assume my old Pioneer puts out .5v and i have my amps set up for it.  I get happy and buy a new headunit.  The new head unit puts out 4v of preamp power.  I install it and I can barely get the volume up before it is cranking as loud as the pioneer!  Well its not that the deck is better, just that the amps are set to be very sensitive to accommodate the old pioneer.  So i would have to go and turn the gain DOWN to accommodate the new headunit.  In short, there is no perfect spot to set the gains.  I personally: 1. do a little listening to the components(sub off)  to set the EQ (bass and treble, loudness off), when i feel i have achieved a good sound   2. turn the gains all the way down on my amps  3. turn my deck all the way up  4.  turn up the amp gains on the components until they just start to distort, back them off just a tad.  5. bring the bass, turn the sub amp on and turn up the gain until i feel i have achieve balance.  Your crossovers will vary depending on your speaker size.  Some people say that you should not turn your deck all the way up to set, but i do because 1. i don’t use deck power  2. people want to get in your car and CRANK it until they hear speakers popping.  This way, the volume is maxed and they assume it cannot get any louder.  I have people say, "that’s as loud as it goes?   you dont have enough power to pop the speakers? how do you know they cannot go louder?  my friend can make his speaker pop, he's got major power."  Yeah, yeah, good for him.  Blah.
Date Posted: August 27, 2004 at 11:42 AM
Oh, the battery.  The light usually means that your battery has low voltage.  If you continue to play your system does it stay on?  If you turn your system off does it go away after a short while or right away?  Are you sure your battery is good?  Have it charged and tested.
Posted By: switch_hitter
Date Posted: August 27, 2004 at 4:08 PM
sounds like you need a new alternator, if you are running 3 or more amps, it would be a good idea to get one...
As far as your bass sounding muddy,, you have 15s, i normally set the crossover no higher than 50hz for 15s...
2 Memphis HPO 12s
1 Memphis 1000D
2 Memphis 8s
1 Memphis MC200
4 Memphis 3way 6 1/2s
1 Memphis MC3004
4 Memphis Tweeters
1 Memphis 3-way electronic crossover
2 Memphis 5 1/4
2 Memphis 4s
Posted By: Marshallmadman
Date Posted: August 27, 2004 at 5:50 PM
   This is just an opinion. I think you should sell all of those amps and get yourself a good Class D Mono amp to run your subs. Unless you have hours to tune and tweak, there's no way you are ever going to get those three amps all on the same page. You are getting cancellation. Instead of the speakers working together to move air, they are working against each other to some extent. A class d mono amp will also be easier on that alternator.
I'm just a regular guy. I don't know why all the fuss about me....
Posted By: stevdart
Date Posted: August 27, 2004 at 6:47 PM
(...to heavilymedicate-you need to start writing in paragraphs, interesting stuff to say but it is just impossible to read that much without breaks...)
To the subject:  You can do a few different things with your system.  Marshalltown is right in that you are using more power from the car than what you are ending up showing.  Three stereo amps will necessitate a HO alt.  You could trade out the amps for three mono amps capable of a two ohm load and use half the power, and might not need to upgrade the alt.
Second possibility, is to trade out the D4 subs for D2's and use the amps you have now.  This will also mean you upgrade the alt.  But to get the most with what you have now, you should rewire the subs to series for 8 ohms each and bridge them to each amp.  You'll then get 300 watts each instead of the 230 each are getting now.  And you'll be using both channels.  Right now they are one-channel driven.
Third, the Audio Control Matrix line driver should be connected near the head unit to get the maximum benefit of its use.  Manual is here.
Posted By: jeffchilcott
Date Posted: August 27, 2004 at 9:24 PM
Well frankly I would have to go with what was said before I would sell all three amps and get a single mono amp to run the subs
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: nyguy4u
Date Posted: August 27, 2004 at 9:25 PM
Thanks for the responses guys.
The idea of one amp to run all 3 of my subs doesnt sound like a bad idea. It seems that my current set-up now isn't even half the power my subs can handle, am I correct with that?. I would assume going with a class d amp, that my subs would probably sound 50% louder.
Say I go with the majority here and do in fact trade in my 3 amps, for 1. What would be a good choice of amp for the maximum bass possible that my subs can handle?. Again, I have 3 JL 15's W3V2's, dual 4ohms in a sealed chambered box.
Wouldn't I need a pretty large amp to run 3 of these subs?.
Money isn't too much of an issue, so I would like suggestions on some higher end amps if all possible.
Thanks again for all the help you guys are giving me.
Posted By: stevdart
Date Posted: August 27, 2004 at 9:39 PM
Here is a Crossfire mono amp.  The subs will wire to 2 .67 ohms as shown below, so the match up is pretty good.
posted_image
Still, your line driver should be up front.
Posted By: customsuburb
Date Posted: August 27, 2004 at 10:55 PM
How about Alpine's MRD-M1001 or JL's 1000/1. Say goodbye to your warranty if you buy from the above retailor.
Posted By: nyguy4u
Date Posted: August 28, 2004 at 12:03 AM
I might be leaning towards the JL 1000/1. Using that particular amp, is that the absolute most I could push my 3 15"s with?. Or is even the 1000/1 not using my subs to the fullest potential?
Posted By: stevdart
Date Posted: August 28, 2004 at 2:36 PM
As i said earlier, you can run 300 watts to each sub with what you have now.  You'll be doing the same with a 1000 watt amp at 2 ohms, maybe getting even less.  Look again at the ohm load you get when you wire those three subs together.  An alternator upgrade is necessary any way you go.
If you want the full potential of your subs, all you do is add up the RMS of the three subs:  500+500+500=1500.  Your amp(s) will need to output 1500 watts.  Each sub alone will wire to either 2 ohms or 8 ohms.  The three combined will wire to 2.67 ohms.  Using that as a guide, you would have to find an amp or combination of amps to achieve that 1500 watt output at the given load.  The Crossfire I showed above outputs 2000 watts at 2 ohms, so with a combined load of 2.67 ohms the output will be closer to 1500.
Again, if you want that kind of output, it is necessary to upgrade all wiring and the alternator, and probably the battery.  But keep in mind just because a subwoofer has an RMS of 500 watts it doesn't mean that you have to give it the full wattage for it to sound either good or loud.  300 watts each will most assuredly be loud, and you'll be using less resources from your car's electrical system to achieve that.
And note to the link above:  If I show an amp, it doesn't matter to me what web site I find it at.  I'm not showing a retailer, I'm showing a product.
Posted By: nyguy4u
Date Posted: August 28, 2004 at 10:34 PM
Well now I don't know what to do, i'm confused.
Here is what I did tonight though.. I changed what my friend did (which I stated a few posts back), and bridged each amp to each sub, changed the amp to "mono", wired the subs in 4 ohm, took the crossover on the amp down to 50, and took the LP crossover on the deck to 50 as well. I had it like that for about 4 hrs tonight, almost nonstop with a pretty maxed volume (we had a car show in town), and it never once cut out, no battery light ever showed up on my dash, I was turning heads waaaaaaay before I got to them, and even was setting off parked cars alarms with my bass.
So, with this current set up, approx how much do you guys think each sub is getting?. If I did decide to go with a crossfire, or JL 1000/1 amp, would I be really gainging that much?
With all that said, knowing how my friend did it, and what I just did to it.. why did he have it wired up like that to begin with? (amp in stereo, pushing 1 channel to subs, subs wired for 2 ohms). It sounds soooooooooo much better my way.
Any ideas?
Posted By: stevdart
Date Posted: August 28, 2004 at 11:00 PM
...That's why I suggested you wire it this way!  The subs are D4's, so now they're wired to 8 ohms, by the way.  8 ohms bridged to each amp yields 300 watts to each sub.  And no problems with the lights,etc.?  Leave it that way.  You're turning heads and are happy with the sound...no need for a change, is there?  The JL would yield the same results as far as wattage, because putting all three subs together  would make the ohm load higher, as I showed you before.  The advantage would be less amperage pull from the alternator.   The bigger 2000 watt Crossfire would increase the wattage to 1600 watts total.  Most likely would cause a need for alternator,etc upgrading.  But no need to be that loud, is there?
Posted By: nyguy4u
Date Posted: August 28, 2004 at 11:07 PM
And that is why I DID wire it this way, because of your suggestion lol. I had it this way up until my friend rewired it though, why do you think he did that?. Being the wattage going to each sub was lowered, I cant really see what benefit I had.
You think I should still invest in a higher output alt with my current setup?, and if so, what should I upgrade it to?
Posted By: stevdart
Date Posted: August 28, 2004 at 11:47 PM
Your friend is the only one who can tell you why he wired it that way.  I thought you said you originally had the subs parallel-wired in the first post...which should have created some serious problems with the amps.  As far as more upgrades are concerned, use it for awhile and see what you think.  It didn't seem necessary from what you described from tonight.
Nope, I looked back at it and you didn't say how they were wired.
