Interference
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38333
Printed Date: April 07, 2026 at 2:15 AM
Topic: Interference
Posted By: ravenndude
Subject: Interference
Date Posted: August 30, 2004 at 10:23 AM
For a while now i realized that one of my speakers are distorting when my sub hits. After some testing i found that my front left speaker cuts out when my sub hits and then distorts when it come back it. When i hit the switch to turn the remoted lead for the sub's amp off the speaker hits fine. I asked my buddy who just started taking Electronics classes at a tech school and he said it sound like some kind of mechanical interferince. here's my setup:::
Two RCAs from HU (JVC KD-SX990) running to the 4ch amp (MTX Thunder4244). Then an RCA running from the 4ch to the 2ch bridged amp (RF 360.2)
The 4ch is powering a pair of Pioneer TS-A6960R (Rear 6x9s) and a pair of TS-A1670R (Front 6.5s that i believe are in // with my stock tweeters)
The bridged 2ch amp is powering an infinity kappa perfect 12.1
Thanks for anyone that can help me ... I'm kinda stumped on this one. But then again i'm thinking of replacing all of the speakers in my car except for the Infinity ... but that won't be untill at least spring break
Posted By: kgerry
Date Posted: August 30, 2004 at 5:21 PM
i'm suspicious of a mechanical cause of a problem like that.... have you tried to cross-channel these speakers? ( switch left to right and right to left ) does the same speaker still have this problem or did it switch over to the front right now?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Date Posted: August 30, 2004 at 6:14 PM
o00o i didn't think of that .... i'll try that next.
Posted By: jeffchilcott
Date Posted: August 30, 2004 at 9:26 PM
Just a long shot do you have your stock tweeters wired in series with your front sprekers?   If so you would probably be yeilding a 2 ohm load, lower impedences tend to cause more distortion, and also makes it harder for crossovers to block frequencies do to increased power
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Date Posted: August 30, 2004 at 11:55 PM
Unless i'm thinking wrong (which is very possible) this is //
posted_image
Posted By: chevyman26
Date Posted: August 31, 2004 at 12:07 AM
Umm, wouldn't two 4 ohm speakers in series be 8 ohms, not 2?
And to simplify it a bit - // (parallel) is just the two speaker's +'s tied together to the + out of the amp (or hu) and the two speaker's  - 's together to the amps - out.
You'd better get me out of this lord... or else you'll have me to deal with. -- Hunter S. Thompson "F.A.L.I.L.V."
