box design suggestions
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38373
Printed Date: April 06, 2026 at 4:40 AM
Topic: box design suggestions
Posted By: stang351w
Subject: box design suggestions
Date Posted: August 30, 2004 at 10:48 PM
hello, i'm planning on running 3 pioneer tsw-2000spl 12" subs in my 1995 dodge neon, the system i have planned is running one box 4.5cu/ft (1.5 cu/ft for each sub)  i'm planning on having a peice of plexi across the opening ot the trunk that you see when the seats are down , then having 2 of the subs on 45' angles towards the center of the trunk and the third sub going straight across  to form this shape "  \_/ " with the top of the pic the back seats, my only prob is i plan on having the middle sub inverted so looking back you see the magnet of the sub, would this affect any of my over all sound or would it be such a small change it wouldn't be anything to worry about, i'm also doing it to hopefully save some space.
Posted By: auex
Date Posted: August 31, 2004 at 12:43 AM
Well, what kind of box are you going to be building with 4.5 cu/ft? The idea for the \_/ would look good/better made with fiberglass, if you are up to it. Inverting subs don't make much of a difference in sound, but you have to remember to wire the inverted sub in phase (make the cone move in and out) with the others
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: August 31, 2004 at 7:13 AM
hello, i do plan on fiberglassing it, i just finished mobile dynamics  and now i wanna put my new found skills to use (no market for high end custom work around here) the subs are going to be in a sealed box  because i don't have any space left to put ports that would make them usefull (ie: towards the back seats)
