Removed HU, Car doesn’t start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38682
Printed Date: May 13, 2026 at 10:40 PM
Topic: Removed HU, Car doesn’t start
Posted By: ravenndude
Subject: Removed HU, Car doesn’t start
Date Posted: September 06, 2004 at 2:21 PM
Car: 1999 Hyundai Sonata V6 Automatic Trans
Yesterday I removed my entires system to try and find where some distortion was comming from. I removed my Tweeters and a could ground loop isolators that were doing nothing.  After i reassembled everything I went to start the car I couldn't turn the key. I have power because my lights turn on. But when I put the key in I can't turn it.
My friend said that since this was the first time i've ever removed my HU (circuit city put it in) i could of activated some kind of security device that locks the car ignition. How trues is this. Does anyone know if I have this on my car? If not does anyone know what elsee could of happened
I tried to look for loose wires under the dash and anywhere where I had audio equip. I checked all of my fuses under the hood. The car aslo has some kind of aftermarket alarm and keyless entry on it. I believe that it is called code alarm (I'll double check when i can).
The only thing is now i'm 160mi away from my car at college. There's a locksmith going to look at the car tomorrow but I don't know what he'll be able to do, but he said he'll check it out (And its covered by AAA) If not i guess i'll be towing it to a Hyundai dealer and see what they can do.
Posted By: stratusfear69
Date Posted: September 06, 2004 at 5:16 PM
If you can't turn the key, it sounds like a mechanical problem, and nothing to do w/ u removing your system.  Sounds like the lock cylinder is bad.  Did u try to turn the steering wheel a little while turning the key?  Some cars have a lock mechanism if u've locked up the wheels.
If u do bring it to the dealer, don't mention anything about what u did.  Let them troubleshoot from scratch.
Posted By: Alpine Guy
Date Posted: September 06, 2004 at 5:58 PM
sounds like you turned the steering wheel and it locked on you, , , all you gota do it turn the wheel hard and turn the key.   Tell your parents to do that before AAA makes you look like a tool.
Date Posted: September 06, 2004 at 6:01 PM
i tried that already. My wheel is lock ... the wheel is 180 degrees fromt he normal position. But i can't move the wheel at all. I tried that. It too al lot of effort to try and move it and the key still wouldn't turn.
Date Posted: September 06, 2004 at 7:48 PM
wow ... i feel like a f**king ass ......................... my dad got in my car and turned the wheel one in to the right and it started right up. Now that i'm 160mi away from home i can't get it till the weekend =(
I was trying so00o f**king hard to turn the wheel left to straighted the wheels. =(
Date Posted: September 06, 2004 at 8:27 PM
                           posted_image   <<<<<!!!
Posted By: flynntech
Date Posted: September 06, 2004 at 9:44 PM
It's happened to me while working as an installer.
It was hot, I was irritated and I tried to turn on a car I had been working on. I said "this thing is a sh*tbox, we need to get this out of here, the ignition is stuck!"
The other guy came over and turned it on like there was nothing wrong at all. I felt like a real dumbass... sometimes it needs the magic touch!
