Sound Deadening? Poly-fill
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38721
Printed Date: May 13, 2026 at 10:21 AM
Topic: Sound Deadening? Poly-fill
Posted By: mrdragon
Subject: Sound Deadening? Poly-fill
Date Posted: September 07, 2004 at 3:02 AM
Hi everyone
Just of of curious....can Poly-fill be used as Sound Deadening??? My car rattle when the sub hit!!!
Cheers
Posted By: kfr01
Date Posted: September 07, 2004 at 7:09 AM
Not really, it will help soak up some of the waves, but won't do much to keep the metal from vibrating.  It might even have a negative effect on your bass.
New Project: 2003 Pathfinder
Posted By: russ lund
Date Posted: September 07, 2004 at 5:13 PM
No! you will have to lower the resonant frequency of the pannel that is viberating.This is done by weight(dynamat,deadbeat etc. or add a brace to the pannel.
BigDog
Posted By: Ravendarat
Date Posted: September 07, 2004 at 5:33 PM
Also polyfill absorbes moisture so if it collects any type of water, which can happen in a vehicle from time to time, then it will soak that up and leave it resting against metal which causes rust which causes holes which causes your car to go faster, weigh less, but look worse. You must prioritize
