2000 Durango Factory Amp bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38808
Printed Date: May 13, 2026 at 8:16 AM
Topic: 2000 Durango Factory Amp bypass
Posted By: DurangoFLman
Subject: 2000 Durango Factory Amp bypass
Date Posted: September 08, 2004 at 3:20 PM
Does anyone know of a harness or have a wiring diagram of how to bypass the stock infinity amp. I want to install a new HU, amp, and sub. Thanks
Posted By: raydawg357
Date Posted: September 09, 2004 at 7:42 AM
You don't have to bypass the factory amp unless you are replacing the factory speakers. From what you've listed, you can still use your factory amp to push your internal speakers. The blue/white wire from your new HU will turn on both the factory amp and your sub amp.
------------- Do it right the first time
Date Posted: September 09, 2004 at 8:36 AM
I have already replaced the factory speakers. The were not amplified they were standard 4 ohm. A new higher powered HU will work with the stock amp? I would think it would be volume sensitive.
Posted By: kgerry
Date Posted: September 09, 2004 at 9:57 AM
if unsure use a differential converter between the HU and the OEM amp......
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
