1993 Cadillac Seville deck install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38888
Printed Date: May 14, 2026 at 9:04 AM
Topic: 1993 Cadillac Seville deck install
Posted By: crkoceja
Subject: 1993 Cadillac Seville deck install
Date Posted: September 09, 2004 at 9:29 PM
I have a 1993 Cadillac Seville and I need help installing an aftermarket receiver. I bought a wiring harness for the car but it doesn't seem to fit the oem harness behind the factory deck or the cdm harness in the trunk behind the power antenna. I used a 32 pin Gm harness but I can't figure this out. If anyone has any ideas on how to install in this car please reply.
Posted By: chevyman26
Date Posted: September 10, 2004 at 12:08 AM
Take the aftermaket harness back and check to see if it is the right one, or if they have another for it. Take a look at the others that they have, see if any look the same as what you have in your car. Maybe you have a Bose system and the harness is for non-bose, or vice versa.
You'd better get me out of this lord... or else you'll have me to deal with. -- Hunter S. Thompson "F.A.L.I.L.V."
Date Posted: September 10, 2004 at 11:23 AM
Or even better, try to have the car at the store with the headunit out so you can try it right there, and if it doesn't plug in just bring it right back in.
