Golf 96 front speaker wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38954
Printed Date: May 15, 2026 at 10:38 AM
Topic: Golf 96 front speaker wire
Posted By: goomba14
Subject: Golf 96 front speaker wire
Date Posted: September 10, 2004 at 9:48 PM
I just bought 2 new pioneer speakers ans I would like to know how do find what wire (of the two) i need to connect to one of  the wire that is attached to the speakers.  Does it matter wich one I use?
Also in the rears speakers there is 4 wires what should i do?
thx alot for your time
Posted By: 12-volt_guy
Date Posted: September 11, 2004 at 1:30 PM
Yes, it matters.  All speakers need to have the same polarity so the cones are all moving in sync.  Otherwise you will lose a lot of bass.
For the fronts, check if you have these colors.  If so, connect them as POSITIVE:
Left:   BLUE/BLACK
Right:  RED / WHITE
If the rears have 4 wires, are the connected in PAIRS to the same two terminals?  If so, do you have separate tweeters or rear door speakers?  Then they are probably just jumping the other speakers with the extra wires.  Just connect each pair to your new speakers in the same manner.  Look for these colors as POSITIVE:
Left:  RED / LT. GREEN
Right: BLUE/LT. GREEN
