1994 toyota camry, rear speakers
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38994
Printed Date: May 15, 2026 at 8:20 PM
Topic: 1994 toyota camry, rear speakers
Posted By: jare
Subject: 1994 toyota camry, rear speakers
Date Posted: September 11, 2004 at 6:47 PM
I need help on how to dismount the rear speakers in this camry 94. thanks
Posted By: shadowinfector
Date Posted: September 11, 2004 at 9:23 PM
first take off the weather stripping in the middle hole when you drop your rear seats then pop off the two rear side panels and the brake light panel.....after the brake light there should be 2 10mm bolts holding it ...remove those and disconnect the brake light. the two side cushions have to be removed...these are really hard...u have to pull up and outward....after that the rear deck should just come out...i just did this car last night...email me of im me if any problems....shadowinfector@aol.com
Posted By: jare
Date Posted: September 12, 2004 at 5:13 PM
thanks a lot, i'm going to try. and i'll let you know.
Posted By: jare
Date Posted: September 12, 2004 at 6:56 PM
in less than 5 minutes,i followed your instructions and that 's all. thank you again.
