sound4 CM97 cassette wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39535
Printed Date: May 13, 2026 at 10:45 PM
Topic: sound4 CM97 cassette wiring
Posted By: dabby22
Subject: sound4 CM97 cassette wiring
Date Posted: September 22, 2004 at 6:12 AM
i have a sound4 cassette player model no: CM97 and i want to wire it up to a car battery for external use not in my car. but it only has six wires 4 speaker one, black ground one and a red igniton one with a fuse, i just want to know how i could wire this to a battery, any help appreciated
cheers
Posted By: mo12v
Date Posted: September 22, 2004 at 8:43 AM
What are the color of all your wires:
MO
Posted By: Chad7n7
Date Posted: September 22, 2004 at 9:26 AM
Dabby,
There should also be a yellow wire on the harness, this is your memory / constant +12V, but if not, try black on ground, red on positive see if you get anything, if not, then more than likely this harness is missing that wire, possibly pulled out of the plug.
Posted By: kgerry
Date Posted: September 22, 2004 at 2:35 PM
he did say it was just a cassette player.... is this the case? just cassette ? not ETR cassette?
if so, just hook power to the positive terminal and ground to the negative terminal.... hook up your speakers and your off and running.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
