classed amps
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39643
Printed Date: May 15, 2026 at 6:13 AM
Topic: classed amps
Posted By: dirtylooks
Subject: classed amps
Date Posted: September 23, 2004 at 8:15 PM
whats the diff.between  a high current amp  and a class d amp or class ab amp ...any info welcome
A way of life..
Posted By: vdubmk4
Date Posted: September 23, 2004 at 8:28 PM
https://www.crutchfieldadvisor.com/ISEO-rgbtcspd/learningcenter/car/amplifiers_glossary.html
that should answer all your questions.
Fortune: You will continue to take chances, and be glad you did.
Date Posted: September 23, 2004 at 9:03 PM
thank you vdubmk4
A way of life..
Posted By: 94legend
Date Posted: September 23, 2004 at 9:13 PM
It really does clear up some inquiries I had, that useful webpage taught  me alot of things I didn't even know or care to think about. Awesome. Thanks for the tip!
Posted By: vdubmk4
Date Posted: September 23, 2004 at 9:16 PM
Hey, no problem. 94legend whatdu plan on using the amps on you need ?
Posted By: stevdart
Date Posted: September 23, 2004 at 9:35 PM
A high current amp is not a class of amp, but an indicator of build quality.  Lower ohm loads on an amplifier will cause the amp to respond with a higher amperage to voltage ratio.  Amperage = current.  So the amp provides a high current when loaded with a low ohm load.  Generally these amps are sought for subwoofers when you want to run them at a 1ohm load.  High current wouldn't apply to the front soundstage, where you would want to run the speakers at the normal 4 ohm (sometimes higher) load.
Posted By: 94legend
Date Posted: September 23, 2004 at 10:08 PM
hey, the amps are
For a customer vehicle that we are still working on, Haven't decided what  amps and speakers to use.  The size of the speakers that will fit in the stock barring is 6 1/2. So far with some help from a member here we will be using the
ts-w2000spl premiers'. And as for tweeters for the highs, not sure. Some suggestions, or any suggestions will help us. Thanks
