trunk rattle
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39962
Printed Date: March 18, 2026 at 9:34 AM
Topic: trunk rattle
Posted By: leroy185
Subject: trunk rattle
Date Posted: September 28, 2004 at 10:20 PM
hey i've got a pair of 15w3's in a sealed enclosure in my 93 buick regal. whenever i turn up my bass at all my trunk sounds like it's gonna fall off. would a layer of dynamat fix this or do i need to tighten some bolts as well?
Posted By: thapimpfromchi
Date Posted: September 29, 2004 at 12:52 AM
do both. might take 5 more minutes, but its worth a shot. however, i dont think a single layer will do the trick, u might have to go over it a few times. take time to listen to the car from the outside and see which panels rattle the most, then layer them up.
1990 Honda Civic HB:
Clarion DXZ545MP H.U.
2- 6.5" Power Acoustik interiors
Diamond Audio 600.1 amp
Diamond Audio 15" M6MKII
Pyramid PB881X 4 CH. Amp
Posted By: raydawg357
Date Posted: September 29, 2004 at 8:11 AM
You might want to invest in dynamat trunk kit and cover your entire trunk
Do it right the first time
Posted By: Rushman
Date Posted: September 29, 2004 at 8:34 PM
Dynomat on top of Dynomat untill it stops but some cars no matter what you do are gonna rattle. Put somthing behind the license plate too.
Posted By: NINsane18
Date Posted: October 02, 2004 at 10:15 PM
I had a 93 Regal with the same problem. When you dynamat the trunk, it adds extra weight, so the trunk lid might not stay open by itself. There is a bar that you can move to a different position under the rear decklid to add more spring tension. Take the taillights out and put dynamat around the screw holes, and like Rushman said, behind the license plate.
Tim-May!
Posted By: leroy185
Date Posted: October 02, 2004 at 10:33 PM
cool thanks guys
Posted By: jeffchilcott
Date Posted: October 03, 2004 at 2:37 PM
i would look into rubberized undercoating the whole trunk. you will be able to get into smaller spaces
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
