1997 Buick Century Power Wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40078
Printed Date: March 20, 2026 at 9:07 AM
Topic: 1997 Buick Century Power Wire
Posted By: soulraven
Subject: 1997 Buick Century Power Wire
Date Posted: September 30, 2004 at 11:26 PM
I was wondering what the best way to run the  power wire through the drilled hole or an existing gromet
Posted By: djv1
Date Posted: September 30, 2004 at 11:38 PM
if there is room in an existing groment run it through there, if not, drill a hole (make sure you aren't going to drill into anything) and you can buy grouments at any auto store, put one in the holle before you run the wire through your it may wear and short out.
JVC deck
6.5in MB Quarts
Rockford 3001M amp
2 12in Kicker Comps
Sirus Sattilte Radio
Posted By: Rushman
Date Posted: October 01, 2004 at 1:06 AM
definately check to see what on the other side before you drill. My Dumb _ss had to buy a break booster after drilling into it. Chalk one up for experience.
