2001 Suburban OEM Radio
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40381
Printed Date: March 18, 2026 at 12:09 PM
Topic: 2001 Suburban OEM Radio
Posted By: bccone
Subject: 2001 Suburban OEM Radio
Date Posted: October 06, 2004 at 6:47 AM
I was looking to buy a OEM Suburban radio on ebay with XM built into the unit.  I've found an '04 unit  but we have a 2001 Suburban.  Will the wiring harness and mounting work from a'04 to a '01?  If so, can I get the factory Satellite radio antenna for the '04 and use it?  Thanks
Posted By: mo12v
Date Posted: October 06, 2004 at 9:20 AM
NO.........04 will NOT fit 01............04 radio is DATA type radio & different size
Will NOT work
If U R wanting XM for your 01, just get the Delphi unit.  It can be removed for In-House use, or portable "Boom Box" available for it.
Otherwise U will have to install aftermarket radio with XM
MO
Posted By: bccone
Date Posted: October 06, 2004 at 9:35 AM
Thanks!
