Mid Bass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40421
Printed Date: March 21, 2026 at 2:29 PM
Topic: Mid Bass
Posted By: need2knowalot
Subject: Mid Bass
Date Posted: October 06, 2004 at 8:37 PM
I do not know a lot about car audio but I have 2 8 in subs pushed by a Phoenix Gold 350 and 2 6 in subs with a Kenwood 250. Is there a way to only send the low bass to the 8's and the highs to the 6's? I know maybe it is a dumb question but i "need2knowalot".
Thanks for your help...
Posted By: jeffchilcott
Date Posted: October 06, 2004 at 11:36 PM
well if you have a crossover on each one of your amps you would set the pG to LPF and the other amp to HPF if you dont have this option you might have a sub out on your deck you would run that to your PG.. if not, then you could purchase a EQ to seprate your frequency's and run your rca's from that to each amp
------------- 2009 0-1000 Trunk WR 154.0DB 2009 1001+ Trunk WR
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: italnpimp59
Date Posted: October 07, 2004 at 1:15 AM
an external crossover is the way to go. you can set the cut off frequency to the 6in subs, and the 8in subs. you dont want two different size subs playing the same frequency because it will cause cancellation
