my car is screwed up!
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40599
Printed Date: March 25, 2026 at 4:51 AM
Topic: my car is screwed up!
Posted By: pimpincavy
Subject: my car is screwed up!
Date Posted: October 09, 2004 at 9:20 PM
I just put a new alternator in my car. After putting it in the car and starting it up, the engine started overheating and antifreeze started spilling out. We put in a new thermometer, that seemed to solve the overheating problem. But then the battery gauge would'nt go past 10 or 11 volts. After the car was running for about 5 minutes (with the system on). The battery gauge dropped to 8 volts and revving the engine didnt raise it up at all. I shut the car off, when I tried to start it, the battery was dead. I came back about 20 minutes later and it started up. The battery gauge was again around 10, revving the engine didnt bring it up, after about 5 minutes WITHOUT the amps on the gauge dropped again, it stalled out, when I tried to start it the battery was dead again. Also, the idle is really rough now, it almost sounds like its going to stall.
Could the alternator not be charging the battery? Everything is hooked up right (as far as I know). The alternator spins fine. Could the serpintine belt not be on correctly? It looks and feels tight enough to me, but I cant think of anything else. I dont really car about the system at this point, I just want the car to run!! Any help would be greatly appreciated.
Posted By: Ravendarat
Date Posted: October 09, 2004 at 9:33 PM
Could be a bad conection at the altenator, could be a faulty battery. Those are my two best guesses. I would probally take the battery to a local shop like Canadian Tire or whatever and get them to test it. If that isnt the problem mabye the altenator is faulty.
Posted By: Rushman
Date Posted: October 09, 2004 at 9:36 PM
speaking of serpetine belt................did you put it on correctly? are you sure the altenator isnt spinning backwards? if you have a Multimeter , check and see what voltage you get off the battery and the new altenator. Also check and make sure there is a sufficient ground from the engine to the frame of the car. Ive seen that problem kill several altenators with a lack of ground . If all else fails , try to get the car to the place you bought the altenator and they should be able to run a few test for you.
Date Posted: October 09, 2004 at 11:30 PM
The only part of the serpintine belt I took off was the part that goes over the alternator, could it be too loose or too tight? I had to loosen it to get it on, but it seems ok now. Where would the engine ground to the car? The alternator that was on the car before this one was having problems to, it was only about 3 months old and still on warrenty at AutoZone So I took the car there and they hooked it up to a machine that tested the battery and alt. They tested okay, but the battery gauge would drop down to 8 volts whenever the engine was at idle, so they gave me a new alternator.
Posted By: Rushman
Date Posted: October 09, 2004 at 11:38 PM
what kind of car is it again? If its a newer car with the serpintine , it will have an idler arm pully that automaticy takes the slack out of the belt. Speaking of which , might wana check that too if your car has one. If its not putting enough tension on the belt , the altenator may not spin enough RPMs. Anybody else have other suggestions?
Posted By: heavilymedicate
Date Posted: October 10, 2004 at 12:44 AM
"Girls love the guys with the cars that go BOOOOM!"
Yeah, chicks also dig guys with cars that run and MOOOVE!  Oh man.  Well, if this problem started right after changing your thermostat I would say it is related to something that happened when it was replaced.  Have the battery tested.  Its odd that it ran till it died, and then started later.  Post the make and model, year to.  If its not the alt or the battery, then it's probably a connection under the hood.  Does it have a separate voltage regulator?  Break yourself, and go get a manual on your ride.  Its only 20$, the same price as a DVD, or a movie in a theater and something to eat, or a tank of gas in a civic, or a lapdance.....
Posted By: rknj01
Date Posted: October 10, 2004 at 1:27 AM
lapdance....
Date Posted: October 10, 2004 at 1:56 AM
Its a 1986 Chevy Cavalier Z24. It does have the arm to adjust the belt, the belt seems to be adjusted right, but I will try adjusting that tomorrow. I do actually have a manual for it. The voltage regulator is built into the car from the factory, however I dont know where it would be located under the hood. Thanks for the help so far guys, ill look things over again tomorrow.
Posted By: Rushman
Date Posted: October 10, 2004 at 1:57 AM
I agree.................lapdance
Posted By: thapimpfromchi
Date Posted: October 10, 2004 at 11:20 AM
hey man, have u ever installed an alternator before? they are very sensitive. you might have shorted the alternator itself. i'd take it to an autozone or something by you and see if its still working. if it is, then we know its something else.
1990 Honda Civic HB:
Clarion DXZ545MP H.U.
2- 6.5" Power Acoustik interiors
Diamond Audio 600.1 amp
Diamond Audio 15" M6MKII
Pyramid PB881X 4 CH. Amp
Date Posted: October 10, 2004 at 3:26 PM
This is the first alternator ive installed. What could I have done to screw it up?
Posted By: Rushman
Date Posted: October 10, 2004 at 3:39 PM
Its not that you did anything to screw it up , You may have just got a bad one out of the box. They are made by Humans which are flawed.
Posted By: chevyman26
Date Posted: October 11, 2004 at 3:13 AM
It is actually more common than it should be to get a faulty alt. First of all, check with a voltmeter to make sure that your guage isn't lying. I'm sure it's not as the car is dying. Don't bother digging around under the hood for the voltage regulator - it's internal on your car, meaning it's inside the alternator. The post that the little single red (usually red) wire at the back of it hooks to is the connection to it.  (Edit:  Oh wait. in '86 you could have either the white 2 wire connector on the side with the little red wire on back, or a 4 or 5 wire on the side only in a GM Weatherpak connector.)  I would take it back to Auto Zone again and haave them check it again, along with your battery. Yeah, they'll probably be getting sick of seeing you, but one of these is more than likely your problem. There isn't muck else in your car that could possibly cause enough of a draw to kill the car.
As said before, check your engine to body and frame grounds. There should be a flat braided steel cable connecting the engine to either body (firewall??) or a framerail. If you absolutely can't find anything that looks like just a ground wire, it wouldn't hurt to add in your own. Just clean it up real good around a couple of bolts.
I think that the thermostat was just an amazing coincidence, as there is nothing electrical about them. Unless some of the boiling over anti'freeze may have gotten into the alternator.....
As far as the belt tensioner, it is not adjustable. Either it is working within specs. or it should be replaced. It is a spring loaded mechanism. I'm not sure what the exact specs. are for your car, but you can use your judgement pretty good if there is enough tension on it. The belt itself could also be bad...  or wet?....
Hope this helps.
You'd better get me out of this lord... or else you'll have me to deal with. -- Hunter S. Thompson "F.A.L.I.L.V."
Posted By: haemphyst
Date Posted: October 11, 2004 at 9:14 AM
(A $20 lap dance?!?! Where the hell can I get one of those?) Ummm.. did I say that outloud?
Anyway, it sounds to me as though your brand new alternator is DOA. If nobody made a mistake in the selection of the alternator at the parts store, or maybe the wrong alternator didn't get packed in the right box, (I have seen it happen) if the old one was working the new one will too. If the old one had adequate grounding, the new one will too (for at least a portion of it's output).   The chance of a little bit of antifreeze waxing your alternator is pretty slim. Those things LIVE UNDER THE HOOD - a hostile environment, at best, with heat, water, the possible occasional boil-over, dirt, dust, bugs, and all other sundrys... and the STILL last 5 to 10 years.
Not that you want to run the car like this all the time, but get it running, and remove the ground cable at the battery. If the car dies instantly, the alternator is indeed dead. If it does not, I would suspect the battery, or a wiring error somewhere. All automotive alternators today have a self-exciting field, so once they start producing output, they will use a part of that output to maintain their own exciter field, this power does not come from the battery.
Posted By: DYohn
Date Posted: October 11, 2004 at 9:46 AM
haemphyst wrote:
(A $20 lap dance?!?! Where the hell can I get one of those?) Ummm.. did I say that outloud?.
They're around, but are usually the type you wish you hadn't asked for after they begin...
Posted By: flynntech
Date Posted: October 11, 2004 at 5:48 PM
If you want to know how to test your alternator, don't do the disconnect battery test. It's a bad habbit and can ruin some cars.
Connect the black  (negative) lead of you DMM to anything with ground potential. The motor or frame or even the negative battery terminal is fine.
Check the positive terminal with the red (positive) lead of the DMM. Check the voltage on the positive connection at the alternator. A good reading should be 12.9/12.6v , higher reading being at the alternator with engine running. A similar voltage drop, .3 or whatever shows the alternator is charging. If you get 12v with the engine ground and alt, but not with the frame/batt ground and alt...this would indicate a bad ground.
Autozone is a great parts store, but it's not uncommon to get some bad luck with some parts, especially alternators. It's happened to me before....just bring it back. Most GMers recomend the rebuilt AC Delco aternators. I had an autozone one in my T/A which lasted years, your's may just be a bum unit.
Date Posted: October 11, 2004 at 8:46 PM
Well guys the car has gotten much worse. It started good once todaym but whenever I gave it any gas it would bog out. The it stalled and the dash started going all weird, flashing on and off and such. Noe the car WILL NOT start, it just acts as if the battery is dead, although all the electrical things sill work, it just wont start. I just want to get rid of it and look for another winter car, but no one is going to buy a car that doesnt even start.
Posted By: Rushman
Date Posted: October 11, 2004 at 9:16 PM
Dont lose your cool Pimp.......Its not as bad as it seems. I know its frustrating Ive been there too many times. Read up on whet the others have said and just have the Battery and Altenator both checked out. Im sure its one of those two or even both. Ive seen that happen recently on a 95 mustang. The Alt. and the battery both had to be replaced and the car is fine. If it makes you feel any better , I have to buy a new battery for my F-150. Gives me the opertunity to buy the optima now.
Date Posted: October 11, 2004 at 11:28 PM
True, but there is still a slim (i agree - very slim) chance. It is always recommended to cover the alt. if you wash your engine. And can you imagine the look on the guys face at autozone when you bring one in for warrenty with antifreeze dripping out?
Dude, just pull out the alt. and battery, have someone give you a ride to autozone, and have them tested. I'll bet you a dime on the dollar one of the two is bad.
Good luck.
Date Posted: October 12, 2004 at 12:03 AM
With the lights working but the car not starting.....that sounds like a definite bad ground to me.
The dash lights doing wierd things and other symtoms really point to a bad ground.
The ground isn't hiding from you, infact if you can't find it.....make new ones.
Buy assembles cables from the store, one with a battery clamp on one end and a lug on the other. Bolt it to the frame of the car. Buy another wire with the lugs on both ends, bolt one end to the motor/transaxle and botl the other at the same place where you bolted the other one. Clean the frame connection real good, get it down to bare metal in the area where the lugs connect, use a star washer and clean the threads very well too.  Apply some di-electric grease to all of your connections to keep the corrosion away.
Chances are, you will find your factory grounds while doing this, leave them in or rip'em out...your choice. As long as you replace what you take off. Most motors have a smaller ground connection on the opposite side, you may find more than one...just clean those connections too.
Use wire as thick as or thicker than the factory ground wiring. (lower numerical gauge size). With a car like that 4 awg will do.
Have the alternator and battery checked again while you're at it.
Ditching a car over electrical problems? No way...don't give in that easilly.....unless you want to give it to me! Is the motor and trans solid?
Posted By: DYohn
Date Posted: October 12, 2004 at 7:57 AM
... or a bad starter or starter solenoid.  Sounds like you need a mechanic, not an installer...
Date Posted: October 12, 2004 at 11:54 AM
On top of all this stuff a vacum line just broke, it must have broken before and the retarded previous owner caulked it back together.  I might try and get it hauled to my friends dads shop and have him look at it.  However I have no money to fix this car, or get another car, so for now I am stuck driving my parents cars, which SUCKS!  If i get desperate im going to sell my system, afterall their is no point in having a system, but no car.
Posted By: Rushman
Date Posted: October 12, 2004 at 11:59 AM
take a 12v battery and put it in the garage. Hook up the system to that and set up a couple of lawn chairs like they were car seats. Isnt that fun???? Im just jokin with ya there. Hopefully your friends dad can get things going for ya at minimal expence. It doesnt sound like anything major like a cracked engine block or blown gaskets.
99 F-one fitty
Pioneer Premier H/U
Alpine EQ
Kicker 1200 amp
4 Kicker comp 10s
6 kicker SS65.2 components
Date Posted: October 12, 2004 at 6:24 PM
Im taking the battery and alt back to auto zone tomorrow to get them tested Hopefully I will get to talk to someone that knows what the hell they are doing. The last two times I went there I had to deal with complete idiots...hasnt made me to keen on taking my buisness there anymore.
Date Posted: October 13, 2004 at 12:06 AM
Hell yeah. When you go there, ask for the manager before you even tell them why you are there. Tell them what's going on and that you are considerering taking your buisness elsewhere and keeping it elsewhere. They will (or should) bend over backwards to help you out.
