1/0 wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40658
Printed Date: March 26, 2026 at 12:02 PM
Topic: 1/0 wire
Posted By: evnldr
Subject: 1/0 wire
Date Posted: October 11, 2004 at 12:55 AM
Is it ever needed to run 1/0 wire to the amp?
Posted By: chevyman26
Date Posted: October 11, 2004 at 2:01 AM
Sure, if you're running anything over 2500 watts RMS, then it would be needed.
You'd better get me out of this lord... or else you'll have me to deal with. -- Hunter S. Thompson "F.A.L.I.L.V."
Posted By: jeffchilcott
Date Posted: October 11, 2004 at 7:30 PM
I am running 1/0 guage in both cars...provides less resistance and also carrys alot of current    100+ amps
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: Asmodeus
Date Posted: October 12, 2004 at 1:08 AM
"Its not loud till you got 1/0 going to your subs...Thats when you are serious..."
LOL....I told a customer that as I was showing him the wire and how big it was.,..The kid almost freaked out...
posted_image
Making the World A Louder Place
Posted By: wayland1985
Date Posted: October 12, 2004 at 5:16 PM
When running high amps ( or mulitple amps ) you need 1/0 to get the most power to the amps.  Also, if you need to run lots of wire between your amp and the battery, it helps to have 1/0 gauge ( but only for huge amps ).  But you can over do it.  You don't need 1/0 for a 300 watt amp 20 feet from the battery.  It's over kill... not to mention that 1/0 ga gets high in price...
~WAYLAND
Posted By: dpaton
Date Posted: October 12, 2004 at 6:05 PM
wayland1985 wrote:
When running high amps....you need 1/0 to get the most power to the amps.
How so? Does that mean I should run 1/0 to my ADS PH15, which is only 70Wx6 downhill with a tailwind? Please, explain. I have no knowledge as to why a HF amp would ever need 1/0 in most situations. Bass is where thhe current surges live, and where the lowest impedence to the battery is required. HF amps have a much smoother power draw (lower crest factor is you will), and the amps power supplies are much more efficient up there. Can you cite a source?
-dave
This is not a sig. This is a duck. Quack.
Date Posted: October 12, 2004 at 11:16 PM
I'm was trying to say high power amps....  I've got over 2200 watts RMS in amps in one of my trucks... and the amps are 18 feet away from the battery....  My application requires either 18 feet of 4 gauge for one amp, and 8 gauge for another  or a much cleaner setup of 1/0 gauge to a distribution block.
You wouldn't need 1/0 gauge for a 420 watt amp....   It's just not what you'd need for that kind of application...
And i'm sure you already knew this....
~WAYLAND
Date Posted: October 13, 2004 at 12:39 AM
Yeah, I was serious about the 2500 watts RMS, at an "average" length. With extra length, you might need it for any over 2000 watts. At the left sid of this page, under the Car Audio heading, click on Power and Ground. or click here https://www.the12volt.com/info/recwirsz.asp. There are some good charts in there.
Posted By: dbdraggirl
Date Posted: October 13, 2004 at 9:32 AM
I've got 1/0 gauge running from my battery to my amp board; from there it goes into a 1/0 -> 4 guage adapter into an (8) 8 gauge block..  and I am running a U.S. Amps 2000x and a U.S. Amps 4300x..  lots o' power.. hee hee.. truely does make a different though..
Girls can do anything guys can do!!
2~12" Kove Armageddon Z's
US Amps 2000x
US Amps 4300x (mids & highs)
US Amps X2R Crossover
Clarion DXZ745MP
2~Kove 5 1/4" KC Components
CompuStar Alarm :o)
Posted By: speedwayaudio1
Date Posted: October 13, 2004 at 10:05 AM
go ahead and use the 1/0 wire there is no such thing as over kill. to much is never enough. you will be all set to upgrade down the road.
Big Dave
