good hf amp?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40773
Printed Date: March 28, 2026 at 3:29 PM
Topic: good hf amp?
Posted By: bullman96
Subject: good hf amp?
Date Posted: October 12, 2004 at 9:28 PM
i am using a kenwood amp kac-7251 which is 150watts x2. got it for almost nothing but am regretting it pretty badly. have a pair of mbquart 6.5RCEs and the amp is clipping. could my grounding be causing this in any way or power? i have a good 14 volts going to the going to the sytem at all times. if none of these are the case, which i doubt they are, kenwood makes crap. what amps should i look into. i am on a bit of a budget. also, how are the pce's compared to the rce's, quality and sound level? i heard the rce's hooked up to a diamond amp and i still wasnt too impressed.
Posted By: stevdart
Date Posted: October 12, 2004 at 10:17 PM
Clipping typically caused by improper gain setting. How did you set it?
------------- Build the box so that it performs well in the worst case scenario and, in return, it will reward you at all times.
Date Posted: October 12, 2004 at 10:27 PM
very low, i have 6.5 volt preouts on my deck so i can crank the deck without any distortion so i have no need to turn up the gain.
Posted By: stevdart
Date Posted: October 12, 2004 at 11:32 PM
Just wondering if you get the clipping when the HU volume is not any higher than the 3/4 point. Even with a high pre-out voltage, a head unit can and most likely will send distortion to the amp, if cranked to the max. I would just check output voltage to the speakers with a DMM first before trashing the amp. And keep the deck at no higher than 3/4 volume.
