2002 Expedition
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40793
Printed Date: March 29, 2026 at 7:17 AM
Topic: 2002 Expedition
Posted By: twisted logic
Subject: 2002 Expedition
Date Posted: October 13, 2004 at 8:29 AM
A friend wants to install 2 amps and a subwoofer enclosure to a factory head unit in his Expedition. One amp for the subs and one for factory speakers. I need to know what he needs to get to make this happen. I think we will need two low level converters and all the power cables of course but is there an easy way to do this? Need a little help here, if he was using an aftermarket deck I would have no problems but this factory deck thing is killing me. Thanks
Posted By: fatgotti
Date Posted: October 13, 2004 at 10:46 AM
Well you basically have everything you need considering your amp has a built in crossover and has a RCA output so you can split the back channel for rears and subs. If not you might want a line driver to keep your signal strong when you split it with a Y adapter. But it still remains it will sound better than it does now but he is going to want an aftermart deck factory sucks.. But that is just my opinion!!! ------------- Fatgotti Yeah my name is John and I am FAT!! YEAH BABY
Date Posted: October 13, 2004 at 11:02 AM
I should not need the crossover in the amp since one amp is dedicated to the subs and the other is for all the factory speakers, correct?
Posted By: Velocity Motors
Date Posted: October 13, 2004 at 12:37 PM
If the back of the OEM deck has one plug, use a 4 channel LOC for the speaker's and most amplifier's have a pass through RCA for a sub amp. If the OEM deck has 2 or more plugs, then you have a OEM amplifier and you need to grab the output wires for the LOC at the output of the OEM amplifier.
------------- Jeff
Posted By: fatgotti
Date Posted: October 13, 2004 at 12:47 PM
Yeah since Expo's have 2 sets of 5x7 they will be ok on full range but what size amp (RMS) are you using on the factory speakers a real inexspensive upgrade would be some aftermarket 5x7's you don't have to break the bank but aftermarkets always handle power better than OEM speakers. If you put to much power on them you will be forced to replace them.
Date Posted: October 13, 2004 at 3:15 PM
The factory speakers are going to be run from a 500 watt Kenwood. i told him they will end up getting blown but he will burn that bridge when he gets to it I guess. I will try and talk him into some aftermarket speakers.
Posted By: fatgotti
Date Posted: October 13, 2004 at 3:40 PM
is that 125x4 RMS or peak ... I truley hope peak because he is going to burn that bridge in a few days if it is RMS.. but any how it has great chatting let me know how it turns out...
Posted By: premieremind
Date Posted: October 13, 2004 at 10:05 PM
If the factory HU is amplified, there will be no need for LOCs for the output is low level to the factory amp!!!!!!
Date Posted: October 14, 2004 at 7:48 AM
That is 125x4 peak. If the factory HU is amplified that would make life alot easier. Anywhere I can find out about where to tie in to all this crap? Thanks for all the help you all have been great.
