amp help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41233
Printed Date: March 10, 2026 at 3:46 PM
Topic: amp help
Posted By: autobots
Subject: amp help
Date Posted: October 19, 2004 at 3:02 PM
im installing a amp and subs in my friends 01 eclipse and shes using the factory deck so she got the loc for the rca cables my question is what wire do i splice the remote wire into. where to run the amp turnon wire to. do i run it to the deck power or what first time ever hooking up on a factory deck and help would be great
Posted By: Ravendarat
Date Posted: October 19, 2004 at 4:32 PM
Just tap into the ignition wire at the deck. That will do fine for your remote line
Posted By: Asmodeus
Date Posted: October 19, 2004 at 4:35 PM
What you need is Accesory power (Key-On Key-Off) So to do this get a test light or a Digital Multi Meter...Unplug the factory wire harness and start testing wires...You Want the one that has no voltage when Key is off....And 12 volts when Key is on...
Once you find it get a wire splice Crimp and make your connection to it...Run a wire to your amps remote and you have it...
You can do the same thing in your fuse box just look for the accesory power and use a Fuse Tap (Get them at Radio Shack or auto parts store) Run the wire from fuse box back to the remote on amp and you are good to go...
posted_image
Making the World A Louder Place
