Wiring For ’86 Chev Nova
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41355
Printed Date: April 03, 2026 at 5:34 AM
Topic: Wiring For ’86 Chev Nova
Posted By: bighauns
Subject: Wiring For ’86 Chev Nova
Date Posted: October 21, 2004 at 7:59 AM
Hey!!
A buddy of mine had his car broken into and his deck stolen.  What they did was they cut on the "car" side of the wiring harness, so there are no stock plugs left for a new wiring harness to plug into.  I was wondering if anyone knew what or where I can find out the stock colors and what they correspond to on the deck harness.  Basically, how do I go about hooking this up without a harness, without guessing and checking every wire.
Any help would be greatly apprectiated.
Thanks!!
Alex
Posted By: bighauns
Date Posted: October 21, 2004 at 8:01 AM
Oh yeah, while I am at it....
Him and another friend tried to hook it up, and they got some stuff working, but when the headlights turned on, the deck would shut off....and when they turned the headlights off, the deck would turn on.  Is this because there is not a proper wiring harness?  Is there an easy fix to this problem?  Will a wiring diagram help that?
Thanks again!!
Alex
Posted By: kgerry
Date Posted: October 21, 2004 at 9:30 AM
they probably have the grey dimmer lead mixed up with the grey speaker wire.....
you have to be careful because there are 2 greys, 2 yellows and 2 browns and they serve different functions.... verify all your wiring with a meter before you begin.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: bighauns
Date Posted: October 21, 2004 at 10:25 AM
Cool, yeah I haven't seen the car yet, so I don't even know what they tried but that totally sounds right.  Any other suggestions?  I think that I can pickup a reverse harness to turn the stock wires back into plugs again :-) and then get the normal wiring harness in case he wants to switch decks again in the future.
Thanks!
Alex
BRING ON THE BOOM!
