2004 cavalier radio colors
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41573
Printed Date: May 15, 2026 at 5:15 PM
Topic: 2004 cavalier radio colors
Posted By: coldfusion
Subject: 2004 cavalier radio colors
Date Posted: October 24, 2004 at 7:40 PM
hey i searched the whole site and i found looks of wiring harness diagrams for remote starts and stuff, but no stock 2004 cavalier radio wiring diagrams. i was just wondering if anyone knew what each color was? Thanks!
Posted By: stevent
Date Posted: October 28, 2004 at 2:55 PM
I would buy a harness and match the wires up to the descriptions on each wire then return it. Thats what a lot of people do to my company.
Posted By: kgerry
Date Posted: October 28, 2004 at 3:27 PM
yeah, there are a lot of sleazy, low end, bottom feeders that pull that trick...which is why we finally had to make our policy "No Returns" on Metra harnesses......
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: russ lund
Date Posted: October 29, 2004 at 11:23 AM
Amen kgerry!
BigDog
Posted By: BoominRolla
Date Posted: October 30, 2004 at 3:57 PM
Someone correct me if i'm wrong but dosen't the 2004 Cavalier have GM'S DATA BUS? The harness for this vehicle should cost you around $75. If you cut the harness off solder it back on, cutting the plug off could hurt the vehicles diagnostic system and the engine... It says this in the owners manual... We've had to solder back on numerous plugs kids that "knew what they were doing" cut off... One ended real bad... Girl had her friend install her deck (Pioneer from wal mart) He in turn ended up when all said and done... Frying the factory deck, factory amp, and pioneer head unit... so probably anywhere between $800-$1000 worth of equiptment... But this was in a malibu or impala I believe?... So save urself the time, agrivation, and money by finding out if ur car has this data bus any local shop should be able to look into the car at the radio and tell you but i'm 99.99999999% sure you have it... and you should be able to buy the harness, dash kit, and antenna adaptor from them all for under $100 and do the job yourself in about an hour or so?.... I'm not trying to be rude just trying to inform you of your thinking about cutting the plug off or tapping into those wires...
