Ground led to H/U metal ok?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41602
Printed Date: May 15, 2026 at 5:12 AM
Topic: Ground led to H/U metal ok?
Posted By: mrdragon
Subject: Ground led to H/U metal ok?
Date Posted: October 25, 2004 at 6:44 AM
Hi just a quick question regrading ground lead....can i wire the "GROUND" lead on the HU metal?????
Will it damage the H/U if i do that?
Posted By: Rushman
Date Posted: October 25, 2004 at 10:42 AM
It sounds like your asking can you ground the radio to itself? I would say no if thats what your asking. You need to find a good spot under or behind the dash. A piece of dash mounting bracket or even something close to the floorboard. If you look aroung under there you may even see places where the factory has a few gounds. Those would also be ok places to ground.
99 F-one fitty
Pioneer Premier H/U
Alpine EQ
Kicker 1200 amp
4 Kicker comp 10s
6 kicker SS65.2 components
Posted By: DYohn
Date Posted: October 25, 2004 at 10:43 AM
Your HU case should be at ground potential, so depending on what you're talking about it won't hurt anything.  What "ground lead" are you thinking of connecting here?
Posted By: mrdragon
Date Posted: October 25, 2004 at 2:27 PM
Well you know how there is Power, Acc and Ground????...that is what i try to connect.for new car audio H/U.
Posted By: Rushman
Date Posted: October 25, 2004 at 2:30 PM
oh yes Im sorry , I miis understood you earlier. You CAN indeed hook up to those same factory wires to the new radio. They should serve the same purpose.
99 F-one fitty
Pioneer Premier H/U
Alpine EQ
Kicker 1200 amp
4 Kicker comp 10s
Posted By: mrdragon
Date Posted: October 25, 2004 at 2:35 PM
One more thing i got a 1994 Camry and atm the front speaker is 4" should i replace it with a 6x9 if so how hard to replace it, i am going to run a 12" sub in the rear.
Posted By: Ravendarat
Date Posted: October 25, 2004 at 3:52 PM
Are you asking if you can replace your front 4 inch speaker with a 6X9. If so shame on you :) Its not a good Idea at all. If you want to go bigger stay with a round speaker and mabye do kick pods or something to that end
Posted By: Rushman
Date Posted: October 25, 2004 at 5:42 PM
square peg in a round circle.........
99 F-one fitty
Pioneer Premier H/U
Alpine EQ
Kicker 1200 amp
4 Kicker comp 10s
Posted By: jeffchilcott
Date Posted: October 25, 2004 at 5:53 PM
i hate 6x9's      when you hear 6.5 components over any 6x9 guess whats gonna win...I will always run componenet sets all the way around the car
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: 1st place sound
Date Posted: October 25, 2004 at 9:36 PM
ground all grounds to one central spot. this is called star circutry. just like your tail lights. thiis is the most important part of your car audio system. please check out the connection going to your starter the eye lid rots out fast.
1st place sound if the windows arent shaken youv been taken
