Boxes for components ?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41639
Printed Date: May 14, 2026 at 10:00 PM
Topic: Boxes for components ?
Posted By: vdubmk4
Subject: Boxes for components ?
Date Posted: October 25, 2004 at 7:00 PM
I plan on adding another pair of components to my car on the rear deck. I was wondering if it would be more benificial to make sealed enclousures for them or just mount them free air style ?
Fortune: You will continue to take chances, and be glad you did.
Posted By: kfr01
Date Posted: October 25, 2004 at 7:03 PM
Most components are not made for small sealed enclosures.  I personally wouldn't spend money on components for rear fill.  If you want some fill back there some cheap coax speakers should be fine.
New Project: 2003 Pathfinder
Posted By: boxmaker85
Date Posted: October 25, 2004 at 7:32 PM
kfr01's got a point.  Back end's not the place for comonents.  You want to stage you're music so bring all the highs to the front.  Go with a 5.25 for the back or less.  You could put them in a larger sealed area especially of they're open to the trunk and you've got a "sealed trunk with a sub.  The sub's pressure can interfere with the speakers playing ability.
Posted By: vdubmk4
Date Posted: October 25, 2004 at 7:54 PM
Sorry, i forgot to state that I would be putting the new components in the front and moving the stock components to the rear deck. Boxmaker85 you made a good point about the subwoofer interference, thanks.
Posted By: Sweekster
Date Posted: October 25, 2004 at 8:03 PM
I would consider going with a coaxial (if you want highs in the back). Unless your doing a surround sound type of set up...going with another full component set in back is kind of over kill.
Duane...
If you think you're confused, imagine how you feel.   posted_image
Posted By: Rushman
Date Posted: October 25, 2004 at 8:08 PM
I remember in the 80s and 90s cars came with that cardboard and foam baffle that came stock under the rear deck speakers to help insulate them from the trunk I guess. Anyway , Im thinking somthing like that should be sufficient enough to prevent interference from the subs. Just a suggestion.
99 F-one fitty
Pioneer Premier H/U
Alpine EQ
Kicker 1200 amp
4 Kicker comp 10s
6 kicker SS65.2 components
Posted By: vdubmk4
Date Posted: October 25, 2004 at 8:09 PM
Well I think by adding speakers (coax or components) to the rear deck facing veritically I will benefit pretty good since all off my other speakers (components) are at close to floor level. The sound reflection off of the rear glass should give me the on-ear plain that I am hoping to get, plus if I have extra speakers that are pretty decent I might as well put them somewhere right.
Posted By: jeffchilcott
Date Posted: October 25, 2004 at 8:16 PM
I am running components all the way around one of our vehicles, but that is because it is an sq car that can also achive 144 db, we have sealed the whole deck in the rear off and placed the components through the rear window deck and molded them in using a little fiberglass... But they are deffintally right coax's are normally more then enough for rear fill,      I will never run 6x9's again since I went to rears that were round
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: vdubmk4
Date Posted: October 25, 2004 at 8:20 PM
Nice, yeah I would kinda like to get my car heading in the SQ comp. car area.
Jeff, how many speakers do you run in the SQ car ?
Posted By: kfr01
Date Posted: October 25, 2004 at 8:29 PM
https://www.crutchfield.com/S-Fn08JkHasQ1/cgi-bin/ProdView.asp?i=237XT62&id=morephotos&a=&s=0&cc=01&g=762#morephotos
Foam baffles like this are a cheap way to help kill some of the subwoofer interferrence.
Date Posted: October 25, 2004 at 8:56 PM
dang kfr01 too fast for me.   Just bout to say that.  Keeps the speaker isolated.
Posted By: Sobe_Death
Date Posted: October 27, 2004 at 12:26 PM
and, if you cover those foeam baffles with a little fiberglass resin then they will eliminate it all together.
